Author Topic: 1979 CR 250 fork options  (Read 8395 times)
TM BILL
Re: 1979 CR 250 fork options
« Reply #15 on: June 25, 2010, 08:26:56 pm »
Thanks blokes thats great  :D i have a couple of sets of 43mm Yamaha forks so thats probably the go. however as Moto pointed out what triples do i use  ??? can i do as liquer suggest and get some original clamps and get them bored out .
if so anyone got some triples for sale  :)
« Reply #16 on: June 25, 2010, 09:10:35 pm »
You can use the CR480 triples with the '79/'80 steering stem, it fits straight in or use the YZ triples and press the YZ stem out and machine a bush to fit the '79 CR stem.
Offline motomaniac
« Reply #17 on: June 25, 2010, 09:34:50 pm »
Machine a bush sounds good.I wouldn't rist the triples of a prolink.
Liqueur
« Reply #18 on: June 26, 2010, 07:16:04 am »
You wont get away with boring originals out to 43mm, 41 is the maximum you can get away with in the standard yolks.
Liqueur
« Reply #19 on: June 26, 2010, 07:18:48 am »
Get a set of 41mm 450 legs, have standard 79 250 yolks bored out to fit, makes a much nicer job and the feel of the front end is better.
37mm bored to 41mm ! you took alot of meat of the clamps there mate.hope that they hold up.
Have done loads of them here in the UK, been doing them for 17 years without a problem. ;)
TM BILL
« Reply #20 on: June 26, 2010, 08:13:36 am »
Paul what do you use to bore them thanks Bill  :)
Liqueur
« Reply #21 on: June 28, 2010, 05:22:04 am »
I have them done on a milling machine with the clamping bolts finger tight.
