Author Topic: Trouble identifing frame  (Read 15521 times)
Offline caps 999
Re: Trouble identifing frame
« Reply #15 on: June 24, 2010, 08:05:51 am »
But the frame num ber Dosent match any listed leith I have the Honda I'd book I think it may be a replace frame as they come with diffent frame numbers
MUGEN power
« Reply #16 on: June 24, 2010, 05:53:24 pm »
That's what I was thinking - kinda like the engine numbers on replacement XU-1 engine blocks.
Offline caps 999
« Reply #17 on: June 24, 2010, 07:33:56 pm »
exactly i know yamahas hve replacement frame numbers that are differnt so people cant rebirth stolens as easy
MUGEN power
ianscr250
« Reply #18 on: June 25, 2010, 09:52:56 pm »
the shock resy mount is an indication its a 125 as the 500 had the ressy for the shock on the left side
« Reply #19 on: June 25, 2010, 10:04:47 pm »
It can't be a 125 or 250 it has no radiator mounts, they were all watercooled with the removable subframe. Has to be '83 or '84 air cooled big bore.
I also think it's a replacement frame with the part number stamp.
« Reply #20 on: June 26, 2010, 09:04:48 am »
G'day Brad,
just saw this thread, i have an original 85' CR500RF frame in the shed (its your's  if you need it but it needs some work on bottom frame rails, footpeg mounts etc.) , i will take some pics for you to compare. i also bought a frame of US ebay some time back.
i will see if i can do this tonight as off for the day with Mini Hoony
090
« Reply #21 on: June 27, 2010, 12:14:42 am »
Thanks Hoony.
« Reply #22 on: June 27, 2010, 10:13:44 am »
here is my frame for comparison Brad
note the difference where CDI mounts (vertically behind head stem rather than horizontally abobe the coil )  also tank mounts are different ? the radiator mounts on mine, how does it compare to your 500RE & 480RD frames?
Mine
Your's
[/quote]
Mine
and your's
« Last Edit: June 27, 2010, 10:25:37 am by Hoony »
090
« Reply #23 on: June 28, 2010, 05:36:20 am »
Thanks for doing that Hoony. Every thing says its an '84 500 frame. It looks like my 84 frame all but a few minor differences. At this stage I will call it a replacement frame due to the small differences and the weird frame number. John T had a good look on the weekend and its definitely factory numbers and not dodgyed up as the grain marks are in the metal (not ground back).
The two things that don't compute are that you wouldn't think there would be 2112 replacement frames built or special frames built either.
I might throw it on mxtrax to a wider audience.
« Reply #24 on: June 28, 2010, 08:31:53 am »
Have you rang a Honda dealer or Honda Australia yet? They will have the answer.
Offline RED ALERT
« Reply #25 on: June 28, 2010, 02:23:38 pm »
Looks like an '84' an 83 would have the reservoir mount and chain roller bracket on the opposite sides to that frame
090
« Reply #26 on: June 28, 2010, 04:19:21 pm »
Yes rang an old school parts guy and even he had no answer.
It is an '84 but no solution to the frame number.
STW996
« Reply #27 on: June 28, 2010, 05:15:21 pm »
Hey Joel, sure its not a Suzuki frame painted red :D :D :D
« Reply #28 on: June 28, 2010, 07:34:10 pm »
Thanks for doing that Hoony. ...................
.................I might throw it on mxtrax to a wider audience.
No worries Brad-o-Slav! :D Let us know what you find out about the Frame Number, could be a very interesting Find? did you say it was from Yank Land?
090
« Reply #29 on: June 28, 2010, 07:57:58 pm »
No. The guy i bought it from got it from a wrecker.
