Author Topic: PE250B parts  (Read 1802 times)
Offline frostype400
PE250B parts
« on: May 09, 2010, 05:20:18 pm »
Pulled my pe250b stuff out and was having a look and getting keen to put it together but need a few bits and peices to do it such as forks triples an exhaust system and wheels would just about have it rolling I have all the key bits to do it if any one has anything please pm me thanks Michael. :)
1971 tm400 and PE's
Re: PE250B parts
« Reply #1 on: May 09, 2010, 05:52:05 pm »
Front wheel is the same as all 80-82 twinshock PE 250/400. 77 uses same hub and same size alloy rim. The only differences you may find is spoke nipple hole size and possibly the grade/thickness of the alloy isnt is different to 80-82 but to the eye there is stuff all difference. Im pretty sure that the 77 doesnt have those rims with the little lip on the sides. So basically you will find your 400 front wheel slips right in ;)
Offline frostype400
Re: PE250B parts
« Reply #2 on: May 09, 2010, 05:56:42 pm »
Ok cool I have a spare 400 wheel that sorts that one but dont have the forks and trees they are definetly different and I imagine rear wheel is too.
1971 tm400 and PE's
Re: PE250B parts
« Reply #3 on: May 09, 2010, 06:07:12 pm »
I have a '79 PE250 rolling chassis taking up space.
Offline frostype400
Re: PE250B parts
« Reply #4 on: May 09, 2010, 06:08:35 pm »
Also if other bits will fit please feel free to advise I'd like to build this as another vinduro bike so I can still go when the 400's are being worked on.
Interesting K does any one know if i could run 79 forks and trees?
1971 tm400 and PE's
Re: PE250B parts
« Reply #5 on: May 09, 2010, 06:18:16 pm »
79-82 TS250 forks with the short underhang below the axle are also very close to the original 77PE forks. Same with SP370/400  and DR400S forks that are all 36mm and have the short sliders and are shorter overall than 78-82 PE forks.
Offline frostype400
Re: PE250B parts
« Reply #6 on: May 09, 2010, 06:25:43 pm »
If I have to buy forks thats ok I would'nt mind original ones just so I know ride hight would be spot on. Thanks for the advice.
1971 tm400 and PE's
Re: PE250B parts
« Reply #7 on: May 09, 2010, 06:40:45 pm »
ebay US will have what your looking for. Usually a lot of 250b stuff there.
