Author Topic: Yamaha DT400 1975 IGNITION  (Read 2181 times)
« on: May 04, 2010, 05:57:37 pm »
I'm looking for a compatible black box for a '75 DT400 Yamaha CDI ignition. I've previously used both MX250 and YZ80 black boxes with this external flywheel CDI on a 250 and now want to try the original ignition curve on my 360. I'm interested in any external rotor Yamaha CDI components and complete units so what have you got?
Offline worms
Re: Yamaha DT400 1975 IGNITION
« Reply #1 on: May 04, 2010, 06:35:47 pm »
i might have something mate, if i do you can have it.
i have a complete DT400 motor in the shed, 75 or 76, so i will have a look and get back to you.
what code is on the cdi ?
Cheers Trev, Worms
« Reply #2 on: May 04, 2010, 07:42:29 pm »
Trev... can i have the piston ?  or the top end if you giving it away ?
freaky
« Reply #3 on: May 05, 2010, 10:51:01 am »
Thanks Trev....Anything ignitionwise you can part with will be most appreciated.
« Reply #5 on: May 06, 2010, 04:24:51 pm »
Is this any good to ya.../quote]
No thanks Graeme, it's the black box I'm looking for. Either a DT, MX or YZ CDI unit...as long as it's compatible with an external rotor DT400 ignition.
« Reply #6 on: May 18, 2010, 10:31:04 am »
Bump..I'm still looking for a CDI module (black box for YZ400/250, DT400/250 or anything else that'll work.
Things are getting desperate...Jeez I might even have to get one off eBay if nobody can help me!
« Reply #7 on: May 18, 2010, 11:27:51 pm »
Firko
will the later model dt250/400d/e 77/78 cdi's do the job?
« Reply #8 on: May 18, 2010, 11:34:02 pm »
Hi Matt, I'm pretty sure they do mate.
