Clubroom
Tech Talk
xl/xr500 into klx250
Topic: xl/xr500 into klx250 (Read 3396 times)
giler
Novice
April 30, 2010, 02:11:20 am »
Hi,
I have seen a couple of pics of these on the sight and realise there is some cutting of frame to do.
How difficult a job is this, re frame, can I use the airbox, exhaust clearance etc?
Any info gratefully received.
Giler
We are not here for a long time, we are here for a good time!
Marc.com
Re: xl/xr500 into klx250
April 30, 2010, 03:58:30 pm »
I have never done it but Mark Meadows did quite successfully. Story goes you chop the KLX frame above the footpegs and cut and paste the lower mounts of the XL500 frame on so you get your XL engine mounts. Nothings impossible.
TT5 Matt
May 02, 2010, 12:30:43 am »
seen one with a 500 yam in it so the honda should slot in,that reminds me to take a dummied up tt500 thumper motor to the wrecker's and try it in a gutted klx frame to see whats invovled
tony27
May 02, 2010, 11:37:01 am »
VMX #41 has an article on a couple of KLX specials, basically the lower half of the frame is cut off & then the lower half of the yamaha frame is mated up to it. Have a read & see if you're up to it, I know it sounds more than I'd like to take on
brent j
Darwin, NT. Suzuki tragic, RL250M TS90MX PE250B
Reply #4 on:
May 02, 2010, 12:45:43 pm »
The Yamaha/KLX in VMX issue 41 is a TT/XT with Green plastics.
I did have a basket case KLX250 years ago and thought of fitting one of my spare TT motors but time and space put an end to that one.
Honda XL/XR500 have been fitted but it would be interesting to see how a TT engine would fit.
One thing that had me holding off on the TT/KLX hybrid was the 36mm forks. I'd fit 38's but you would need to have the same offset to try and keep that sweet KLX handling.
Imagination and $ are the only limiting factors!
Clubroom
Tech Talk
