Author Topic: Yamaha DT Parts  (Read 3267 times)
CaptainFur
Yamaha DT Parts
« on: April 29, 2010, 12:20:14 pm »
Hi all,
I'm after either the full exhaust or at least the silencer/tail pipe in any condition for a DT100A,  I believe silencers from other models (DT125, DT175 etc) will fit.  A previous owner has cut the end of the silencer on my bike.
Also after a speedo for a DT100A or at least the speedo bracket,  I can get a speedo from Ebay etc but the only brackets available are from later models (1977 on).
Low mount front guard or the brackets for it- again a previous owner has butchered the original guard that I could probably repair if I could get the brackets.
May also be interested in any other DT100 parts in good condition eg, Front rim, shocks etc.
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Ban BLACK rims NOW
Re: Yamaha DT Parts
« Reply #2 on: April 29, 2010, 12:58:08 pm »
I wrecked a Dt175 might be a 75 model ? would have all that stuff and a Dt250A in a box, give me a list if they were interchangable.
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: Yamaha DT Parts
« Reply #3 on: April 29, 2010, 01:20:27 pm »
i've got a DT100 pipe {no silencer} i was just about to put the grinder through for no other reason than to squeeze it into the bin.
it's free $, in Brisbane, a little rough but usable.
if you're heading to CD7 i can take it along then or i can post it at your cost.
"flat bickie"
Offline David Lahey
Re: Yamaha DT Parts
« Reply #4 on: April 29, 2010, 05:54:28 pm »
Is the front DT100 wheel rim you want 19" chromed steel?
previous pseudonym feetupfun
CaptainFur
Re: Yamaha DT Parts
« Reply #5 on: April 29, 2010, 06:37:33 pm »
Freakshow - I'll have a look tonight at part nos and see whats compatble but I think the silencer definately is.
vandy010 - thanks, I'll see how I go.
feetupfun - yes 19" chromed steel the one I have is painted, I assume to cover some dodgy chrome.
CaptainFur
Re: Yamaha DT Parts
« Reply #6 on: April 29, 2010, 06:45:10 pm »
Cyclegod - thanks for that, I hadn't noticed that one.
Re: Yamaha DT Parts
« Reply #7 on: April 30, 2010, 10:23:28 am »
What's the Engine ID prefix please CaptainFurball ? Make it alot easier to check my parts if any for you. Cheers Tim754
CaptainFur
Re: Yamaha DT Parts
« Reply #8 on: April 30, 2010, 01:52:20 pm »
Engine ID 437
CaptainFur
Re: Yamaha DT Parts
« Reply #9 on: April 30, 2010, 02:19:21 pm »
It appears the exhaust is different on 100 vs 175 but the silencer/tailpipe is the same on the twinshock models.
The rear shocks are also the same for 100 and 175 twin shocks, I was going to just clean up my existing rear shocks but they are stuffed, one keeps jamning compressed.
I've seen conflicting results on the rims/wheels but think they are probably compatable.
I believe the A (74), B (75), C (76) Dt100 models are very similar to each other, with then only minor differences for later DT100s (77 on)
Offline David Lahey
Re: Yamaha DT Parts
« Reply #10 on: April 30, 2010, 08:38:42 pm »
Sorry the chromed rim I thought was 19 inch is 21 inch
Re: Yamaha DT Parts
« Reply #11 on: May 01, 2010, 10:33:33 am »
Cap, I have a rough 437 wrecker here (from Yzhilly) ;) it has both wheels, frame, most of the engine , oil tank, front end , knackered expipe no muffler, no seat, sidecovers or tank  Rough being the key word. I am in Elmore 3558 North Central Vic. Yours if you want,             price you ask? negotiable around the free mark OK ;)   PS  437 Models have a steel 19 inch front wheel . Cheers Tim754
CaptainFur
Re: Yamaha DT Parts
« Reply #12 on: May 01, 2010, 12:22:32 pm »
Thanks Tim, I think I'll take you up on that.   Will send PM
Re: Yamaha DT Parts
« Reply #13 on: May 01, 2010, 01:38:13 pm »
Free :D cheers
