Author Topic: case half's  (Read 4847 times)
Offline hampster
case half's
« on: April 22, 2010, 05:37:42 pm »
Hi,
What the best to stick case half's together? I just got some three bond 1211 white but normally use yamabond.
Chris.
090
Re: case half's
« Reply #1 on: April 22, 2010, 05:50:06 pm »
Three bond for sure. I think Yamabond is similar any way.
Re: case half's
« Reply #2 on: April 22, 2010, 05:52:54 pm »
Hi,
Chris.
I've only worked on Yammies hence I've only used Yamabond with great results. The tip is to make sure the mating surface is clean and free of all damage and gasket material. It is not a filler ;). Good luck, enjoy  8).
Offline hampster
Re: case half's
« Reply #3 on: April 22, 2010, 07:04:38 pm »
Only today i found out that threebond comes in different grades i have used the grey before but not the white 1211?
Offline dalesween
Re: case half's
« Reply #4 on: April 22, 2010, 07:11:22 pm »
I have used the grey before,works good aslong as everything is clean as Graeme mentioned.
Offline Canam370
Re: case half's
« Reply #5 on: April 22, 2010, 07:35:25 pm »
Threebond 1104 liquid grey is the go.
090
Re: case half's
« Reply #6 on: April 22, 2010, 07:57:45 pm »
Oh okay. Me neither. Always Gandolf the Grey .
Offline hampster
Re: case half's
« Reply #7 on: April 22, 2010, 08:14:59 pm »
well stick to what you know go the grey, have to go and buy some, more bike dollars.
Chris.
Re: case half's
« Reply #8 on: April 22, 2010, 11:20:50 pm »
to clean the mating surface use metho on a clean rag wiped clean by another clean rag,repeat serveral times for a oil free surface and no leaks
Re: case half's
« Reply #9 on: April 23, 2010, 11:28:08 am »
Where is three sold ?
« Last Edit: April 23, 2010, 11:31:32 am by Freakshow »
Re: case half's
« Reply #10 on: April 23, 2010, 12:48:08 pm »
I know Ficeda and MCS sell the Threebond. Its expensive but its good and so many people use it. The jap factories even use it
http://www.mcsonline.com.au/index.php?option=com_content&view=article&id=110&Itemid=41
http://www.ficeda.com.au/
You should be able to get it from Pitmans Freaky as they are MSC and Ficeda dealers.
Offline hampster
Re: case half's
« Reply #11 on: April 23, 2010, 07:14:10 pm »
The cost can vary from a bike shop $40.00 got some today from a well stocked auto shop $17.00 the same item.
Chris.
