Author Topic: YZ Fork Dampener Rod Wrench  (Read 2403 times)
Ji Gantor
« on: April 21, 2010, 08:33:23 am »
My broom handle wrench has worn down so much from rebuilding forks that it is time to buy a new one or build a proper tool.
To build the proper tool I used some 8mm mild steel round bar and a 5/8th nut.
This wrench is to hold the dampener rod while the retaining bolt is torqued up or down.
Some dampener rods have a socket end. Check your manual to see if yours does and what size the socket is.
Ji
Ji Gantor
Re: YZ Fork Dampener Rod Wrench
« Reply #1 on: April 21, 2010, 08:46:31 am »
Cut the round bar to length and notch one end.
Ji
Ji Gantor
« Reply #2 on: April 21, 2010, 08:47:55 am »
Fit the round bar together and hold it in place with a welding magnet.
Ji
Ji Gantor
« Reply #3 on: April 21, 2010, 08:49:25 am »
TIG weld the round bar T handle continuously.
Ji
Ji Gantor
« Reply #4 on: April 21, 2010, 08:51:32 am »
I lathed up an insert which I pressed into the nut and then feed the other end of the 8mm round bar T handle into.
Ji
Ji Gantor
« Reply #5 on: April 21, 2010, 08:52:56 am »
Continuously TIG weld the nut, insert and 8mm round bar.
Ji
Ji Gantor
« Reply #6 on: April 21, 2010, 08:55:21 am »
YZ fork dampener rod wrench cooling.
Total cost of materials $4.00.
Total time of manufacture 1 hour.
I think that the broom handle would have cost about that and it takes me more than 1 hour to get out of Bunnings.
Ji
« Last Edit: April 21, 2010, 09:24:38 am by Ji Gantor »
monaro308
« Reply #7 on: April 21, 2010, 12:35:13 pm »
I had to make the same thing for my 85 RM125 forks last week except the RM has a 29 1/2 ish mm hex in it.
Great to see you back on here Ji Gantor always look forward to your work!
cheers....mario
