Author Topic: RM250X  (Read 3050 times)
Offline Bikeaholic
RM250X
« on: April 19, 2010, 07:35:31 pm »
Trying to sort out the front suspension on my RM250X. Set the oil height as per manual. Springs are stock etc. Still very soft through the stroke. Thinking it may need more oil and perhaps some spacers. Other than that can anyone advise me on a suitable setup and perhaps different springs and or valving to make these skinny forks work the best they can. Prefer to keep it standard looking as apposed to fitting later model forks. Dave
Offline SUZUKI311
Re: RM250X
« Reply #1 on: April 19, 2010, 08:10:18 pm »
i have a RM250X which i have fitted a later set of forks to, but as you wish to keep it original contact Nick Dole at Teknik in Sydney, supply him the O.D, the free length and what rate you require and he will set you up with the correct springs. i also had a set of fork emulators left around from another bike,which i fitted. With the standard forks fitted they are definitely too soft both in the spring rate and the oil control. i weigh around 87kg, and the spring rate supplied was .44 For most VMX tracks this set up is quite good, play with your oil height from the std capacity for bottoming resistance.
Offline Bikeaholic
Re: RM250X
« Reply #2 on: April 20, 2010, 08:39:30 pm »
Ist time of doing this. Hopefully it worked. Before and after pictures of the RM rebuild.
Fingers crossed Barrabool will be the day to try her out properly.
Thanks for the tips on the suspension
All Things 414
Re: RM250X
« Reply #3 on: April 20, 2010, 08:44:06 pm »
Very nice  ;)(however I think that tank's gunna have your nuts... :P)
suzuki43
Re: RM250X
« Reply #4 on: April 20, 2010, 08:59:07 pm »
Awesome stuff,great to see another Full Floater beauty ready for action.
Offline holeshot buddy
  • sunshine coast qld
Re: RM250X
« Reply #5 on: April 20, 2010, 09:25:47 pm »
bike looks good they were a great model 8)
set oil level  150mm from top forks collapsed springs out
go for a heavier oil
motul 2 stroke gearbox oil is perfect trust me
fit a 20 mm spacer on top of spring
if its still a bit soft  add 10 psi of air
that should do the trick ;) ;D
follow me to first turn
