Author Topic: reborn  (Read 6586 times)
rm nut
Re: reborn
« Reply #15 on: April 15, 2010, 06:23:45 pm »
sadly i had not first time around bikes in 23 years had the same year model bike when i was 17 thanks gazza
rm nut
Re: reborn
« Reply #16 on: April 20, 2010, 10:15:51 pm »
i am at the stage of pulling my hair out the old girl will not run right it is like there is a block some where it just will not hit the band just got stator back from vic today had it rewound and wired with no change  i have the muffler off now will test with it off in morning to see if there is a block i am grasping at straws now have one more day before 3 day ride for Anzac weekend 70+ riders i am open to  any guesses thanks gazza
Offline SUZUKI311
Re: reborn
« Reply #17 on: April 20, 2010, 11:09:49 pm »
Its a long shot, a young gun used to road race one around here in the mid eighties, and at one meeting the bike started no worries, but would not run anything over the pilot jet. Turned out the young bloke had re-packed the muffler, and in his desire to seal EVERYTHING up he used great lashings of silicone on the muffler/pipe joint, which ended up with a massive blob of silicone partially blocking the muffler. When muffler was taken off, bike was faultless, so you may be on the right track with the muffler. i assume the top end, reeds, carb etc are all ok?
rm nut
Re: reborn
« Reply #18 on: April 21, 2010, 07:51:01 am »
had a full top and bottom rebuild carbie new second hand floats new needle new needle slide new needle seat new throttle cable rewound and wired electric I'm hopping it not the cdi only thing i have not replaced this has been 1 costly Itch i had to scratch
Offline suzuki27
Re: reborn
« Reply #19 on: April 21, 2010, 09:50:28 am »
Not long back I got my 125E motor rebuilt, top and bottom etc, and it would not rev out cleanly. After checking  carby, tank breather ,fuel tap filter, swapping coils and CDI's, and as it turned out, numerous other things- for example I found a rag in the fuel tank- don't ask me how! I was twitching every time I looked at it. One day , when grasping at straws ,I took the mag cover and noticed the the nut that holds the rotor was not on the shaft as much as the other RM sitting beside it- so I grabbed the rotor and wobbled it and sure enough it had both in and out movement and  was loose on the shaft/keyway. This is the way it came back from the engine builder. Tightened it properly and we both lived happily ever after...till next time!
rm nut
Re: reborn
« Reply #20 on: April 21, 2010, 12:48:18 pm »
have worked out problem fingers crossed ran it this morning with out the muffler on went like a dream to my neighbors discuss muffler at muffler shop now getting cut and cleaned out hope this fix problem if it is you will hear the yaahooo from what ever state your in gazza
