Author Topic: PE250T Pipe and/or Muffler  (Read 1399 times)
TT
« on: April 02, 2010, 09:23:30 pm »
The header section of the pipe on my PE250 is a bit average, so I'd like to replace it with a better one.
Email, pm or call me on 0410 504 815 if you can help. Cash waiting.  ;D
btw I have also considered the Muskett replacement header. Anyone used one?
« Last Edit: April 03, 2010, 03:18:07 pm by Tony T »
Offline matcho mick
    • Moto Tumbi
Re: PE250T Pipe and/or Muffler
« Reply #1 on: April 02, 2010, 09:43:22 pm »
Tony T,i've got a smiko muffler with your name onit,pm me your addy, :P
« Reply #2 on: April 02, 2010, 09:44:21 pm »
I have used the musket repairs but not on PE's There is a few guys on the PE forum who have used them though and i know one guy was very happy as the musket repair was made from a lot thicker metal. They should be set up and welded on the bike to get them in the right position though. I usally find lots of tiny cracks in pipe around the spring loops. if you end up using the one you got give it a full burn out inside. Its makes them really clean, lighter and shows up any more cracks or holes in them.
Also with the mufflers, they will be all clogged up with oil and the packing will be usless and the bike will be loud. Get the muffler cut open, take out the perforated core and clean it, re-pack with new packing and weld it back up again. Its can all be done neatly to look like it has been worked on.
« Last Edit: April 02, 2010, 09:46:57 pm by LWC82PE »
TT
« Reply #3 on: April 02, 2010, 09:58:27 pm »
Thanks Mick. pm sent.  ;D
Sounds like the replacement header might be a reasonable option. If I haven't found a good pipe in the next week or so, I'll go that way.
And I'll get you to put it togther for me, Leith. (I've only got an arc welder.  ;)
« Reply #4 on: April 02, 2010, 10:04:36 pm »
I reckon you might want to get it TIG welded, but i dont know anyone local with one.
TT
Re: PE250T Pipe
« Reply #5 on: April 02, 2010, 10:15:20 pm »
Thanks. I'll look into it.
« Last Edit: April 03, 2010, 03:17:51 pm by Tony T »
