Author Topic: V6 Rodeo.  (Read 11853 times)
Curly3
V6 Rodeo.
« on: March 24, 2010, 09:04:56 pm »
I know this is not a VMX topic but it surely is related as I bet there are a few guy's out there who own one.
The early RA 3.5 engine has a bit of a history for shitting itself prematurely as mine did last week.
As I've discovered today the problem stems from the disintegration of the Catalytic Converter and the particles going back into the engine ( Dusting ), hence the Crank is Knackered in mine after only 100K.
I've investigated every possibility of repair and have decided to go with a fully reco'd donk which has had the recirc port blanked off, total cost inc a clutch $6200.00 inc gst.
I'm not a mech genius but given the history of my engine it all makes sense to me.
Hope this info may help someone else and of course any expert feedback is welcome.
There goes my project bikes for a while.
DOH.
Re: V6 Rodeo.
« Reply #1 on: March 24, 2010, 09:17:34 pm »
Rodeos are shitbox's, petrol or diesel, cant think of anything good to say about them apart from when they come into my workshop I know I'm gonna make some money!!!
Offline number8
Re: V6 Rodeo.
« Reply #2 on: March 24, 2010, 09:25:09 pm »
DOH.
My sons has developed some expensive noises just today,like the mains are stuffed,it's an RA V6 petrol as well,who did you get the Reco motor off?
#8
Offline number8
Re: V6 Rodeo.
« Reply #3 on: March 24, 2010, 09:26:12 pm »
How much is a bottom end rebuild normally,
#8
Curly3
Re: V6 Rodeo.
« Reply #4 on: March 24, 2010, 09:34:19 pm »
No 8, a bottom end rebuild was approx $3K and dusting means shit in oil and the top end would've been affected as well I've decided to go the whole hog for price of mind?
Curly3
Re: V6 Rodeo.
« Reply #5 on: March 24, 2010, 09:39:28 pm »
Make that piece of mind, the cost has affected my thinking. I'm in Syd if that helps.
Re: V6 Rodeo.
« Reply #6 on: March 24, 2010, 09:44:47 pm »
G'day Curly,
what year is your rodeo? i have a 2004 RA and wondering if mine is what you refer to as "early RA 3.5  V6" mine has done 55K.
Curly3
Re: V6 Rodeo.
« Reply #7 on: March 24, 2010, 09:51:18 pm »
Hoony, mine was a 03, somewhere around 07 they went to a 3.6 Holden Engine so yours would be the same engine. Sorry.
Re: V6 Rodeo.
« Reply #8 on: March 24, 2010, 09:54:14 pm »
Bugger.
Thanks Curly ( i think)  ::)
Re: V6 Rodeo.
« Reply #9 on: March 24, 2010, 10:16:15 pm »
Davey, Davey.. My 2.6 4 cylinder Rodeo has done 390,000k's travelling from race to race around the country and the engines never been apart and it still runs strong and doesn't use oil.
Re: V6 Rodeo.
« Reply #10 on: March 24, 2010, 10:19:03 pm »
You know you've just put the mockers on it Johnny! ;D
Offline floberts
Re: V6 Rodeo.
« Reply #11 on: March 24, 2010, 10:24:51 pm »
What about getting a low kilometre engine out of a wreck or from the importers?
Ben
Curly3
Re: V6 Rodeo.
« Reply #12 on: March 24, 2010, 10:26:05 pm »
Hey Hoony, if it helps you avoid the same shit fight then it's good. When I find out where this port or whatever it is, is, I'll let you know, but it appears shit " Cats " are the main cause.
Re: V6 Rodeo.
« Reply #13 on: March 24, 2010, 10:39:42 pm »
He's probably talking about the EGR valve, their causing alot of problems with petrol and diesel engines nowdays, shit fuel doesnt help either.... DONT use anything with ethanol in it!!
Re: V6 Rodeo.
« Reply #14 on: March 25, 2010, 12:51:22 am »
Davey do you suppose I should update my cat less ,OHC less ,fuel injection less, computer less *,no power windows, steering, or air conditioning straight 6, 4 speed manual 1978 HZ Holden one tonner ? $6200 buys two and a half fully re manufactured long engines. Then again I could remove the six pack and straight bolt in one of the Holden Red V8s I have in the shed for nothing ,in say 3.5 hours........ ;)
*it does have an early electronic ignition ..luxury no points :D
« Last Edit: March 25, 2010, 12:53:03 am by Tim754 »
