Author Topic: YZ250C / YZ400C / YZ125X / YZ175 1976 rear shock  (Read 21698 times)
Re: YZ250C / YZ400C / YZ125X / YZ175 1976 rear shock
« Reply #45 on: May 05, 2010, 08:24:06 pm »
Actually i can see it in the pics, so short answer is it has the shock mainline
« Reply #46 on: May 05, 2010, 08:58:44 pm »
ah yes, but that's a 125c shock, whereas i was after a 125X shock, or 250C etc....
the 125X shock is about 20mm longer than the 125C unit. The one you have should be the same as those on a 250B etc... albeit with different spring rates. Thanks though.
