Author Topic: IT125 interchangeability of parts question  (Read 19875 times)
Offline 4V5
Re: IT125 interchangeability of parts question
« Reply #15 on: February 23, 2010, 12:31:05 am »
2. Middle. Four short 10m studs out of the cases, that hold the barrel to the cases. Then there's 8mm studs out of the top of the barrel to hold the head on (125s have four 8mm studs, 175s have six).
All monoshock DT125/175s, YZ125D/E/F, IT125, IT175D/E/F have this set-up.
Beware the 85+ DT175 top ends - they run a shorter rod and different piston.
there are two different crankcases in this group, the size of the transfer ports are larger on the later DT175 compared to the earlier monoshock DT's the later DT cases are also the same as an early IT175.
the IT125 shares the same crankcase as the early monoshock DT with the smaller transfer ports. I'm unsure of what rod it uses though as I've only just started pulling my 125 apart
Cheers!
Leslie
« Reply #16 on: February 23, 2010, 03:39:14 pm »
Thanks for that site. Has anyone got a Yamaha Zedder cross reference and can check what these part numbers are common to
It will save looking though a ton of different parts books online.
3R2-11651-01-00 – rod
3R9-11631-00-96 – std piston
3R9-11610-00-00 – standard rings
18G-11351-01-00 – base gasket
also what is the standard bore size for the IT125? Is there 2 sizes of YZ pistons from 76-82?
I just used a 3R2 rod so i can tell you there easy to get as would be the other kit.
