Author Topic: rake & trail  (Read 5906 times)
Offline EML
rake & trail
« on: February 18, 2010, 10:09:46 am »
Can some-one out there quickly explain rake and trail for my apprentices paper-10 words or less??
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: rake & trail
« Reply #1 on: February 18, 2010, 10:47:01 am »
rake = used for cleaning up dead leaves ;D
trail = used for going flat out on a motorbike :D
"flat bickie"
Offline EML
Re: rake & trail
« Reply #2 on: February 18, 2010, 11:22:38 am »
Thanks Vandy, I'll tell him to put that on his paper to see if he gets a 'pass'.
Any other 'techs' out there?
All Things 414
Re: rake & trail
« Reply #3 on: February 18, 2010, 11:28:55 am »
Rake = the angle that the forks are to the verticle
Trail = the distance from the axle to the verticle of the steering (and I'm not sure if that's the centre of the steering stem or the top of the steering stem or the handlebars or...)
Offline EML
Re: rake & trail
« Reply #4 on: February 18, 2010, 11:56:24 am »
Thankyou Mr super sperm-that will do us
Re: rake & trail
« Reply #5 on: February 18, 2010, 12:11:17 pm »
Trail is the amount in which the contact patch of the tyre 'trails" the centreline of the steering stem if you extended the line down to the ground. More yoke offset less =trail, less yoke offset= more trail
Re: rake & trail
« Reply #6 on: February 18, 2010, 12:25:25 pm »
STEERING 101: How it works.
 The basic elements of steering include rake, trail, and offset.
The trail plays a role in stabilizing the front-end by helping your tire develop a restoring force that attempts to keep your motorcycle traveling in a straight line.  The longer the trail, the more the motorcycle will resist turns and be more stable on straight line driving.  A shorter trail allows for quick and easier turns.  The shorter trail makes the motorcycle want to "fall" into the turns.
The rake plays a role by allowing any lean of the wheel to be translated into a turn of the wheel towards that lean.  A more vertical rake allows the bike to handle bumps and ruts well, HOWEVER, by having a smaller rake you create a smaller trail and forfeit some straight line driving stability.  A smaller rake also produces a lighter handling feel when turning. As you increase the rake, the motorcycle will produce a more heavier or sluggish handling feeling since the weight of the chassis is attempting to self-straighten the fork as it hangs in the steering axis.
The trail and the rake directly affect each other.  If you shorten one, you automatically shorten the other.  The opposite is also true.  If you increase the angle of the rake, you also increase the length of the trail.
The third basic element is the offset.  Offset is defined in millimeters (mm) and is measured from the centerline of the top of the steering stem axis to the centerline of the top of the fork tubes.  An offset provides a second option for the setup of how the motorcycle will handle. The smaller offsets (35mm - 60mm) allows the motorcycle to angle more into the corner and push through the turn. However on exiting the corner, you will experience less traction allowing you to turn easier and stay on the inside of the track.  As you increase the offset (60mm - 75mm) you obtain more traction coming out of the corners, but the greater offset forces the motorcycle into an upright position and you will drive more towards the outside of the track coming off the corner.
Other factors such as weight transer when braking, fork length, and tire size may also play a role in changing the trail and rake and should be given consideration when determining your set-up.
from f
ChrisACT
Re: rake & trail
« Reply #7 on: February 19, 2010, 01:19:32 pm »
As per Lozza's explanation:
DR
Re: rake & trail
« Reply #8 on: February 19, 2010, 01:49:28 pm »
as always a picture is worth a thousand words :D
Offline EML
Re: rake & trail
« Reply #9 on: February 19, 2010, 02:16:19 pm »
exactly what was reqd, a pcture is worth a couple of thousand words when trying to describe it to an apprentice.
Thank you one and all..
Offline ba-02-xr
Re: rake & trail
« Reply #10 on: February 19, 2010, 03:55:29 pm »
That must be a picture on a harly ;D.
All Things 414
Re: rake & trail
« Reply #11 on: February 19, 2010, 06:58:20 pm »
Isn't that what I said?  ::)
Re: rake & trail
« Reply #12 on: February 20, 2010, 12:30:25 pm »
Now on to leading link set ups....... :D
