Clubroom
Vintage Track
where do the footpegs go
Topic: where do the footpegs go (Read 2351 times)
jimson
Sanctuary point N.S.W
January 31, 2010, 10:19:08 pm »
G'day viewers I'm having a go at making a pre78 dirt tracker flat tracker up out of bits I have around the shed anyways about the pegs do they sit level to each other or do you drop one lower say the right side and then raise the left
so you clear the dirt with your left peg and your right leg has room to stretch out ? Is this right. jimson
matcho mick
Re: where do the footpegs go
January 31, 2010, 10:55:59 pm »
KISS mate
,make them both the same,
Freakshow
Superstar
Adelaide, SA - looking for a "YZA" tank
January 31, 2010, 11:42:25 pm »
dont make anything higher, if you feel inclind and have the frame for it 2" down and back on the right is nice, but like mick says, dont waste your time unless its how they came.
74 Yamaha flattracker's
70 Jawa 2 valve speedway's
For sale - PRE 75 Yamaha MX stuff, frame, motors and parts also some YAM DT1,2,A and Suzi TS bikes and stuff
jimson
January 31, 2010, 11:54:25 pm »
Yes well I stuffed up
I had this frame that someone had welded square tube for pegs so the foot peg mount was all over the place I got carried away fixing one side so much that I failed to keep them level :'( jimson
Freakshow
Superstar
Reply #4 on:
February 01, 2010, 01:28:23 pm »
Consider it done then.
Clubroom
Vintage Track
