Author Topic: gear box noise  (Read 3043 times)
gear box noise
« on: January 30, 2010, 07:58:25 pm »
Question , If you had a noisy gear box and leaks oil.  What would you do to fix it on the cheap.
Re: gear box noise
« Reply #1 on: January 30, 2010, 08:13:44 pm »
sawdust is the old favourite isn't it :P depends whether you're selling the vehicle though ;D
TT
Re: gear box noise
« Reply #2 on: January 30, 2010, 08:17:34 pm »
Have you had too many Pepsi's, oldfart?  ;D
What sort of vehicle are we talking?
Re: gear box noise
« Reply #3 on: January 30, 2010, 09:27:57 pm »
Motor bike.          And I enjoy a cuppa.
« Last Edit: January 30, 2010, 09:30:15 pm by oldfart »
Re: gear box noise
« Reply #4 on: January 30, 2010, 09:38:45 pm »
If it's one of your PE's Stu, chuck it in the bin mate!!!..... ;D
Re: gear box noise
« Reply #5 on: January 30, 2010, 09:39:24 pm »
Pull it apart and replace the stuffed bits with cheap NOS parts found on ebay.
Or if its clutch is separate to the gear box then fill gear box with Penrite semi fluid grease or 50/50 semi fluid grease and 50 weight engine oil, just like the old pommy clunkers use to have.
If it was mine i would go with the first suggestion.
TT
Re: gear box noise
« Reply #6 on: January 30, 2010, 09:47:11 pm »
Good idea, Mr. Crocket. My bin's pretty much empty.  :D
Offline frostype400
Re: gear box noise
« Reply #7 on: January 30, 2010, 10:14:10 pm »
frosty has a pe dumping service pays and picks up for scrap PE's anytime Stewart. ;)
1971 tm400 and PE's
Re: gear box noise
« Reply #8 on: January 30, 2010, 10:21:36 pm »
There you go Stu, Frosty's come to the rescue, give it to him....problem solved... and may I add, at no expence to you!!!!.....geez, you owe me a cuppa for that one.
Offline frostype400
Re: gear box noise
« Reply #9 on: January 30, 2010, 10:27:03 pm »
dont chuck it in the bin or I will have nightmares who chucks a bike in the bin. ???
1971 tm400 and PE's
Re: gear box noise
« Reply #10 on: January 30, 2010, 10:47:31 pm »
Just put this out there to see if it was any of your handy work  :)
Had a spare day up my sleeve as I'm waiting for parts again ....US postage is a bit slow of late, So proceeded to pull a few motors down to see what the internals where like  ::)
This one in particular I removed the oil drain plug and found grease WTF going on here ( this will be interesing )
And this is what I found inside  :o   1 and a 1/2 tubes of grease. Must have pumped it up thru oil drain hole.  To my amazement there was no spline or gear damge apart from a burn mark on a seletor.
OK who owned this before me -----TM 250 1973 motor.
Mainline,  your safe there was no saw dust to be found ;)
Top of picture is 1 half of case with gears still in place , bottom is other side. When pull apart it some ended up on crank.
« Last Edit: January 30, 2010, 10:49:44 pm by oldfart »
Offline frostype400
Re: gear box noise
« Reply #11 on: January 30, 2010, 10:54:10 pm »
Now you made me feel guilty  frosty , just chucked some PE  shocks in the bin the other day .
I did that ages ago and I am still upset about it never again will a PE part go in my bin.
1971 tm400 and PE's
Re: gear box noise
« Reply #12 on: January 31, 2010, 12:52:40 am »
Oldfart at least its all oiled up  :P  and not rusted needing 5 cans of CRC  ;D
Its a way too preserve an era ...like embalming a GOD   8)
Offline bazza
Re: gear box noise
« Reply #13 on: January 31, 2010, 03:18:57 pm »
Stu according to uncle Rangi(ex Onehunga United Motorcycle Club president) you should use Lion Red,banana skin and Pukekeo shit. Look forward to a Cuppa at CD.
Embrace patina
