Marque Remarks
Maico
needed early maico decomp lever/perch
Topic: needed early maico decomp lever/perch (Read 2663 times)
paul
January 29, 2010, 06:41:27 pm »
carnt seem to find one ive got the perch but not the lever any body got one laying around for sale .ive got this bit but i need the lever
crabman
B-Grade
Re: needed early maico decomp lever/perch
January 31, 2010, 04:54:20 am »
try a Shimano bicycle lever (same shape) and readily available
Old and slow - and happy
paul
January 31, 2010, 07:59:13 am »
exactley the same and how many
Last Edit: January 31, 2010, 08:09:59 am by paul
paul
January 31, 2010, 11:56:00 am »
the same or different .cause if there different i have different ones
All Things 414
Reply #4 on:
January 31, 2010, 12:51:16 pm »
Quote from: crabman on January 31, 2010, 04:54:20 am
I knew Maico went on to better things
De-comp levers are for girls....
LWC82PE
Superstar
Reply #5 on:
January 31, 2010, 03:24:26 pm »
Is it a early small type magura? if so try this place
http://www.motorrad-stemler.de/
http://www.motorrad-stemler.de/dcenter/down/neuheiten.pdf
It looks a bit like the early Magura perches with the small brake/clutch lever as found on 1950's Adlers
Have you looked at maguras current catalogue? im pretty sure they stilll do a old style short decomp lever
Last Edit: January 31, 2010, 03:27:47 pm by LWC82PE
Marque Remarks
Maico
