Author Topic: re pe kickstart  (Read 3190 times)
Offline oldskool
re pe kickstart
« on: January 24, 2010, 10:26:06 pm »
does anyone know if rm/tm/ts kickstart lever will fit pe175 e.looked on alpha sport the part numbers are different.springwood suzuki sell them new they say there off an rm,i still have the bit that goes on the shaft just need the lever its self,and at $280 springwood suzuki can keep theres.thanx gary.
Offline frostype400
Re: re pe kickstart
« Reply #1 on: January 24, 2010, 10:29:53 pm »
you should be get something universal take the knuckle and the broken bit down to your local bike shop they will measure the spline and should have something in the ball park that will get you out of trouble I know they have cross lists on gear levers that will fit so they should have similar on kick starters :)
1971 tm400 and PE's
Offline oldskool
Re: re pe kickstart
« Reply #3 on: January 24, 2010, 11:33:01 pm »
very helpfull lwc82pe ill ring them tomorrow the first link has a place at coopers plains about 20 min drive from me thanx again.frosty ill go check out shoreline he has a clearence on getting rid of stuff to make room his shop is only about half hour from here spoke to him the other day and he said he had a boxfull of old kickstart levers so between the two i should end up with something thanx all.cheers gary
monaro308
Re: re pe kickstart
« Reply #4 on: January 24, 2010, 11:33:49 pm »
My cross ref with alpha's new part # shows 22 models
RM250's 84-95
RMX250's 89-98
The old # shows only the 3 pe175's......d e z
Offline oldskool
Re: re pe kickstart
« Reply #5 on: January 25, 2010, 10:17:56 am »
thanx monaro i found only the three models as well ill check ouy what shoreline has in his box of bits on wednesday my next day off work thanx again cheers gary
