Author Topic: dt bottem end squeak/vibration  (Read 7569 times)
Re: dt bottem end squeak/vibration
« Reply #15 on: January 17, 2010, 12:32:27 am »
i use a long screw driver or garden hose as a stethoscope with good results but as others have said take the lid off and do a measure up and see where its at,a good way to check cyl taper is use 1 of the old rings and measure the gap at the top of the bore and than down at the transfer ports where 2 pokers tend to wear the most
metalskin
Re: dt bottem end squeak/vibration. and other probs
« Reply #16 on: January 23, 2010, 04:18:07 pm »
i have worked out where that squeak is coming from.. the tank doesnt fit correctly as its off a  dt175,
and when the weird engine vibration kicks in it rattles around. i have since narrowed it down, is only between 3700 to 3900rpm.
        cheers for all the info/help/replys. metalskin.
« Last Edit: January 24, 2010, 12:03:07 am by metalskin »
