Author Topic: Motorcycle shock coil spring compressor tool needed  (Read 11031 times)
Offline PEZBerq
  • Brisbane
Re: Motorcycle shock coil spring compressor tool needed
« Reply #15 on: April 10, 2011, 01:29:27 pm »
Thanks to Freaky's sketch I have managed to get the springs off my ITC Ohlins without losing my sons fingers!  The compressor is a piece of piss to make, doesn't require any welding and works great. Thanks again Freaky  :) :) :) It really pays to google when you are stumped as you never know what you will find. It was cool to find this old OzVMX thread as a high hit which I never even  remembered seeing.
Offline FAT-TOY
« Reply #16 on: April 10, 2011, 08:29:24 pm »
  Purchased a set of spring compressors made for motorcycle springs off US ebay (220434151833) $27.  Comes in a metal case and they have plastic covers so they dont damage the powder coating on the springs and they dont pull of like the car type do.
Everyday I find one more name to add to the list of people who piss me off.
« Reply #17 on: April 10, 2011, 11:53:13 pm »
Good news Pez.  Like ik said you kick yourself when you realise how easi it is to make one, and then when you use em , how easy the shock comes off ? its like hot knife and butter.
I had to pull as hock down at the property the other day and ended up putting a bolt in the end of two short bits of RHS and welded an clip on it, stuck it in the vise and boom shanka, same thing - all caqme apart in 2 seconds, and all of 3 mins to make it.  Cant believe how many times i had previously messed around with 2 screw driver and a prayer.
MAte its like kissing jesu :O) when you get your head around the dodgey easy speing compressor.
Offline Moto
« Reply #18 on: April 11, 2011, 07:41:03 pm »
 I purchased an Ebay set the same as FAT-TOY's, after using screwdrivers and wife with collets for years.The other good thing is they fit in a box about the size of an impact screwdriver,easily taken to the track to adjust preload without having to remove the shocks from the bike.Best $27 she ever spent.
