Author Topic: ID the Rear Hub.  (Read 2337 times)
ID the Rear Hub.
« on: December 31, 2009, 11:16:34 am »
Re: ID the Rear Hub.
« Reply #1 on: December 31, 2009, 11:24:49 am »
Can't see the hub but the tank's cactus.. it's got 2 bullet holes in it. :)
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #2 on: December 31, 2009, 11:25:29 am »
difficult to be sure but it don't look period to me.
brake seems even small for a Yammie.
"flat bickie"
« Reply #3 on: December 31, 2009, 11:29:15 am »
Looks like hes got a floating rear brake on it, maybe a "D" hub?. Front one is later model as well.
Offline vandy010
« Reply #4 on: December 31, 2009, 12:17:32 pm »
floating baking plate is std for that model and a few others and is pre~70 legal as the DT1 rear was floating.
it ain't a "D" hub or even late 70's 125 as the sprocket bolts were still small in diameter up till 79.
after that the chain swapped to the same size as the brake.
i wonder if it's a late model 80? :-\
"flat bickie"
« Reply #5 on: December 31, 2009, 12:22:16 pm »
YZ250G/H/J/K - but probably H+, seeing as it has gold rims.
Interestingly, those bikes have pretty much got a different part number for each year's hub, spokes and rim, despite them all looking the same (apart from the G having silver rims, which explains why the G rim is a different part number))
The brake plate is also from the same era.
