Author Topic: how to build RM125  (Read 3259 times)
Offline Marc.com
how to build RM125
« on: December 21, 2009, 11:18:09 pm »
this is one of the best I have seen recently, built for one of the Coral bosses in the USA, but never delivered, check attention to detail
monaro308
Re: how to build RM125
« Reply #1 on: December 22, 2009, 06:25:19 pm »
Damn it Marc did you have show that!
I have a 125T sitting in the shed thinking what i might do with it as I've nearly finished the "C"
Along with a YZ80H,2 x YZ80K's,2 x CT90's,SL70E..........
Heres the T
The big end seized and the previous owner had an RM100 as a bitsa and used the crank and top end into the 125 cases.
I have all the original bits,just need to rebuild the 125 crank and re-fit to bring it back to a 125 (one day)
cheers...mario
Offline pmc57
« Reply #2 on: December 22, 2009, 09:59:13 pm »
Looks like you've got two different bikes there MarcFX (the one in the air). Regardless I do like the detail on the top one, I like the drilling in all the hardware and the fresh re-built look.
Offline Marc.com
« Reply #3 on: December 22, 2009, 11:21:46 pm »
actually they are come to think of it.
I am working on 125C I scored for $400 the other day, motor is original bore and looks good, the rest arrived in bits.
Loydee
« Reply #4 on: December 30, 2009, 07:31:29 am »
Monaro, what are those rear shocks, Progressive? Just building an RM100 -using 125 forks and swingarm, unfortunately with the RM100 14" shocks it seems to be sitting too low and the 125 shocks are fecked... javascript:void(0);
Offline Marc.com
« Reply #5 on: December 30, 2009, 08:29:43 am »
shocks are too short, try 15.5". You are limited as to what shocks fit the stock frame and swinger.
monaro308
« Reply #6 on: December 30, 2009, 09:50:07 am »
Hi loydee,the shocks came on the bike.They are dual rate spring MDI brand and measure 398/400mm eye to eye.
As marcfx said you will need around 15.5 or 390-400mm and if running the body at the top you will need shocks with the extended mounts at the bottom to clear the s/arm.
I just measured my rm100x shocks at 367mm and the rm125c shocks at 372mm.
I wouldnt mind putting original T shocks back in mine if i can find a decent set.
I tried my C shocks but yeah too short and the bottom shock spring end hits.
