Author Topic: water/vapour blasting  (Read 12670 times)
Offline yamaico
Re: water/vapour blasting
« Reply #15 on: November 11, 2009, 12:42:41 pm »
It's contained in a sand blasting pressure vessel. You can't re-use it as you would in a bead blasting cabinet, so yes, you just point and shoot. The soda breaks down when it hits whatever you are blasting, so it couldn't be re-used regardless.
« Reply #16 on: November 11, 2009, 06:02:17 pm »
Freaky, I've soda blast some of my frames outside on me lawn . As Yamaico has stated 25 kg will go a long way  ( 2 frames easily )
To answer and earlier question by "motomaniac " there is no need to spray a protective coating on after its been  "vapour blasted "
When there is a need  for clear coating over, I use outboard clear acrylic ...by K&H
Offline ola_martin
« Reply #17 on: November 11, 2009, 07:11:37 pm »
What kind of soda are we talking about?
« Reply #18 on: November 11, 2009, 07:40:02 pm »
Schweppes Creamy Soda
Offline crs-and-rms
  • heaven 23
« Reply #19 on: November 11, 2009, 08:16:41 pm »
and how do you make one
Offline PEZBerq
  • Brisbane
« Reply #20 on: November 11, 2009, 09:32:05 pm »
Sodium bicarbonate - baking soda.
Offline yamaico
