Author Topic: PVL Ignition Hates NGK's  (Read 19345 times)
Re: PVL Ignition Hates NGK's
« Reply #15 on: March 15, 2010, 05:23:31 pm »
also may have pupil contaminates within packaging.   :o
« Reply #16 on: March 15, 2010, 06:07:59 pm »
Past employment as a fitter, foreman, leading hand, hire controller and  manager of several “equipment hire depots” I have experienced many a bad batch/box of spark plugs. Wether they are precious metal or not, I have always thought that premature failing of plugs was  because of the porcelain failing due to poor quality control of that component in its production or because of “over crimping pressure” of the metal body onto the porcelain body(that causes the porcelain to fracture and so produces a leak to ground of the coil discharge). When I was a boy, I developed a simple test to prove this the theory about the leakage of the invisible monster that bit me several times. Allthough I use the Guzzlerdore these days as the main test instrument, the test still remains the same and every dud and every box full of duds is quickly exposed.
« Last Edit: March 15, 2010, 07:21:10 pm by MICK-DE »
Offline paul
« Reply #17 on: March 15, 2010, 06:10:22 pm »
looks like the maico factory in days gone by ;D ,at least theve got shoes mick
