Marketplace => Wanted => Topic started by: 35elsinore on August 31, 2014, 09:30:52 pm
Looking for a good set of Honda 73/74 cr250 engine cases and 75 cr125 engine cases.
Cheers Troy
I have a set of 75 250 cases if they are of any use.
I want to build up a spare engine for my 74 cr, I have a couple sets of case but they are not real flash. Sadly the 75 cr250 are different.
Thanks anyway Simon, someone else might be interested in them
Cheers Troy
How good do you want? I will have both 250 & 125 cases but none will be perfect. I also have a couple of MT250 bottom ends, the wide ratio trans works well in CR250's.
Hey BigK, they don't have to be perfect, just aslong as they don't need welding up. I have a few mt bottom ends but are after cr.
Cheers Troy
Have a new stator plate if needed [in nz]--not cheap though, well, not yet anyway. On trademe but might not have re-listed yet, loosing track of my listings [geriatric lol].
I have everything but good cases.
Would consider bottom ends or complete unknown engines if cases look good extenally
Troy
