		Marque Remarks => Yamaha => Topic started by: Shaun G on August 11, 2011, 05:52:43 pm
				A friend has got a YZ250A motor into his workshop for a rebuild. I am hoping some of you Yama-philes may be able to help with some information.
Firstly he is after a rod kit. I suggested Hot Rod's. But is there any suppliers that can be recommended.
Also the barrell does not have a cast iron sleeve. Is this normal for this model? It is apparently a one owner bike and is on the standard bore. And no it is not for sale...I checked ;D ;D ;D
Here are some pics.
(http://i648.photobucket.com/albums/uu202/STG_23/yz250a_2.jpg)
(http://i648.photobucket.com/albums/uu202/STG_23/yz250a_1.jpg)
(http://i648.photobucket.com/albums/uu202/STG_23/yz250a_3.jpg)
Any help is appreciated.
Shaun
				Thought the "A" had chrome barrell?
				Chrome bore is standard , Love those Ti head bolts
....... Love those Ti head bolts
Anodized aluminum I'm sure ;) (I've got 4 but didn't know what they were off ::)).
				The YZ A had Ti head bolts , not sure why they did as they had no other Ti bolts , and even a steel brake lever and steel axles  ???
				Thanks fella's. We couldn't work out the chrome bore thing as we thought they were a later development. So the barrell needs to be re nikasilled then? Who would you recommend to do this?
And Ti head bolts are cool. I also thought they were just anodised???
And what about a rod kit?
Shaun
				Shaun, Give Nick a call at Teknok....47322626
				I’m led to believe the stock length rods are NLA
I’m not sure what models they come from but I believe you can use a later model longer rod kit and a later model piston with a lower deck height so you won’t need to use a spacer under the barrel.
				aluminum anodised.
Yes rods are still available
yes other rods that fit are available, pins over the counter, mains over the counter, washer, small end bearing and gugeon etc too
 yes pistons are but your better of sleeving it then you can have as many oversizes as you like as you wont find the chrome rings anymore there is no reason to save the old chrome liner.
otherway round Geoff you use a lower rod and a normal piston from 74-79 even wiseco and woosner make them for this application
Tell the guy to call me if he wants and ill take him through his options.  there are some easy ways to do this and some hard ways.
				Thanks for the info everyone. I have passed it on to my mate.
Shaun
