Clubroom => Tech Talk => Topic started by: jimg1au on March 26, 2011, 08:21:48 am
Title: looking at buying som nos springs for my 35mm betor fork
Post by: jimg1au on March 26, 2011, 08:21:48 am
dont know anything about spring rates can someone tell me what this means
first set
 Betor forks . S&W # 10-427A / SP2228-20. They are 20" long, and are 1.10" wide, #22-28 spring rate.
second set
betor forks    S&W # 10-427A / S20-20. They are 20" long, and are 1.10" wide, #20 spring rate.
third set
Betor forks. S&W # 10-429A / S22-20. They are 20" long, and are 1.10" wide, #23 spring rate.
these are nos s&w springs
thanks
jim
Title: Re: looking at buying som nos springs for my 35mm betor fork
Post by: JC on March 30, 2011, 09:07:35 am
Jim,
Looks like the 1st set are 22-28lbs/in progressive wound
2nd set 20lb/in straight/linear wound
3rd set 23 lb/in straight
Post by: montynut on March 30, 2011, 10:48:54 pm
Mate I wouldn't waste your money and time with NOS betor fork springs they were very ordinary the first time round and cannot even be compared to buying some modern springs from any of the current suppliers.
I thought all Beter stuff would have been metric not in pounds but happy to be corrected.
Just going through the same thing with my VR Monty forks. Les at Mainly Maico is procuring some nice modern 'proper' springs for my weight  ::) and riding level (or lack there of). I’m expecting a major improvement over the originals frm past experience.
Post by: jerry on April 09, 2011, 08:40:35 am
Can someone help with a source for fork springs for my MK6-7 Pursang ( I believe they are the same forks) I weigh 95 kg clothed for battle. I am of exceedingly average ability and will also have a set of YSS fork valves fitted. Cheers Jerry
Post by: montynut on April 09, 2011, 09:24:55 am
Have just had the exact same job done on my 35mm forks for my VR250 Monty (Betors). Les at Mainly Maico (VMX Unlimited) sourced the springs. You appear to be the perfect weight for your height ;D same as me ;). Phone Les on 0249817241 or I am sure that YSS or any of the other Suspension guys can also help out.
Post by: jerry on April 09, 2011, 01:22:30 pm
Thanks Monty. For the record I'm 8' 19" tall. Cheers Jerry
