Tony.... or anyone else.
Instead of cutting a new key for the pulser rotor I pressed the rotor off and have moved it around to suit the timing. The reason I did this is so that the magnets are closer aligned to the pick up, and because my machinist brother is too busy to cut the key just at the moment..... and I want it now
![Smiley :)](http://forum.ozvmx.com/Smileys/default/smiley.gif)
It obviously does not make that much difference as your bike runs with it in the normal position.
What I query, (how important is it etc). Is the timing of the pulse (voltage) from the supply coils down on the crank. I have been trying to think of the theory behind the CDI's and what i think is so long as there is a voltage being generated for the CDI (capacitor) to discharge then it should'nt matter.
whats your thoughts???
![Huh ???](http://forum.ozvmx.com/Smileys/default/huh.gif)
In my mucking around I also discovered that a boyer pick up could be modified to fit behind the standard ignition cover
![Roll Eyes ::)](http://forum.ozvmx.com/Smileys/default/rolleyes.gif)
. But then your back to a battery again
![Undecided :-\](http://forum.ozvmx.com/Smileys/default/undecided.gif)
Steven
