Author Topic: VMX247 XL350  (Read 64144 times)
Re: VMX247 XL350
« Reply #15 on: May 09, 2009, 08:56:16 pm »
The project is still going on.
Unfortunatelly I giggered a wire on the pulse coil and had to buy another coil. (complete unit) ((glad they are not modern bike prices))
Got that on Friday and fitted to stator plate today. Have been having no end of trouble getting spark today. Will look again at what I have done tomorrow. One of the other guys in VMXWA fitted one at the same time as mine. He kept the plate configuration as supplied and made stand offs to set the stator plate back. Mines the reverse. Plate mounted on cover. He said it was good but noticed distinct steps in the CDI curve. Probably easy fixed for another $50 with the race CDI.
The other WA guy that has his working got the bits via the following link
http://cgi.ebay.com.au/RACING-INNER-ROTOR-KIT-FLYWHEEL-CDI-CRF50-XR50-LIFAN_W0QQitemZ160333513293QQcmdZViewItemQQptZAU_Motorcycle_Parts_Ac
cessories?hash=item25549f424d&_trksid=p4634.c0.m14.l1262&_trkparms=%7C301%3A0%7C293%3A1%7C294%3A30
(If that makes sense.) He brought 2 for what I paid for one.
Anyway Ill let you know on tomorrows outcome if I can get back down the shed.
Steven
albrid-3
Re: VMX247 XL350
« Reply #16 on: May 09, 2009, 10:32:28 pm »
that xl 350 number #50, what frame is the engine in. david
Re: VMX247 XL350
« Reply #17 on: May 09, 2009, 10:45:22 pm »
standard XL frame no mods.  8)
and of course no Maico frame yet  ;)
cheers S&A
Re: VMX247 XL350
« Reply #18 on: May 14, 2009, 08:03:45 pm »
still no spark, doing my scone in over this one. >:(
maybe too much gap between the rotor and pole faces- ??? will move closer today  :P
« Last Edit: May 16, 2009, 09:42:25 am by VMX247 »
Re: VMX247 XL350
« Reply #19 on: May 16, 2009, 09:55:40 am »
found another photo
Offline crossedup2
  • Never enough shed time.....
Re: VMX247 XL350
« Reply #20 on: May 23, 2009, 11:32:59 pm »
This is just a thought 247 but with the stator coil, is it still the same way around on the mounting plate as it arrived? My logic is that the cdi's usually pick up of the pulse running one way, (say North South) generating a + direction pulse (sine wave). If you have turned the plate around but are running the rotor in the supplied direction (South North) you may be generating a - pulse ( sine wave), then those little diode thingise will not allow the pulse to trigger.
Try turning the stator coil over on the mounting plate, if it will fit.
It may be worth a try and should cost nothing.
I like the handy work of your mounting system. I like blending old stuff with new and you look like you've done a great job.
Good luck
PB
Re: VMX247 XL350
« Reply #21 on: May 24, 2009, 12:22:28 am »
The coils are orientated as they were if the stator plate was set back as normal. So the poles are right. What I discovered was the air gap required is absolutly naff all. By mounting the plate as I did it was quit difficult to get the gap right between the coils and rotor. To make it worse the rotor diameter was'nt  very true. We have modified the backing plate a bit by machining out the area near the pulse coil and slotting the mounting holes so that i can get some adjustment and see whats going on. Works ok so far. true test will be race day.
The next version I will keep the stator and coils as normal, machine out the centre of the stator plate then make standoffs to set the stator plate back off of the ignition cover. Doing it that way  makes it heaps easier to adjust the air gap between the coils and the rotor and ultimately ends up less machining to do.
albrid-3
Re: VMX247 XL350
« Reply #22 on: May 25, 2009, 08:21:24 am »
Hi Jim, so your looking for a maico frame to put the engine in.
« Last Edit: May 25, 2009, 07:24:55 pm by albrid-3 »
Re: VMX247 XL350
« Reply #23 on: June 29, 2009, 09:24:08 pm »
Guess where we are going  ;D ;D  :P
][/url][/img]
« Last Edit: July 02, 2009, 08:59:32 am by VMX247 »
Offline Tossa
Re: VMX247 XL350
« Reply #24 on: June 30, 2009, 05:35:44 pm »
][/url][/img]
an XL funeral!!!
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
Re: VMX247 XL350
« Reply #25 on: June 30, 2009, 09:01:13 pm »
funny haha Tossa
Alison
Offline Tossa
Re: VMX247 XL350
« Reply #26 on: July 01, 2009, 11:07:40 am »
funny haha Tossa
Alison
Now, now Alison, just don't raise your hand near me otherwise Christine will hit me!!
Re: VMX247 XL350
« Reply #27 on: July 04, 2009, 03:52:13 pm »
as Tossa's post below.... Box of tricks  ;D
« Last Edit: July 18, 2009, 01:30:58 pm by VMX247 »
Offline mick25
  • Hunter valley NSW
Re: VMX247 XL350
« Reply #28 on: July 04, 2009, 05:29:37 pm »
JUST NEEDS SOME RED PAINT ,,
Offline Tossa
Re: VMX247 XL350
« Reply #29 on: July 06, 2009, 04:14:56 pm »
][/url][/img]
Box of tricks  8)
Best looking XL I've seen!!
