Author Topic: CR 250 Chain Roller  (Read 1684 times)
090
CR 250 Chain Roller
« on: December 30, 2008, 08:21:09 PM »
Here are a couple of shots of the roller i am using, i haven't tested it yet though but cant see any issues. As you can see room is an issue so a small roller is needed. The packet says it all. MSC is the wholesaler. You have to use a smaller diameter bolt so it has to be long enough to go right through with a nut on the end. Hope this helps.
Offline pancho
Re: CR 250 Chain Roller
« Reply #1 on: December 30, 2008, 08:27:54 PM »
do i see the con link on backwards?
090
« Reply #2 on: December 30, 2008, 08:31:50 PM »
If you're standing on your head maybe! Thats the underside 'ol mate  ;)
STW996
« Reply #3 on: December 31, 2008, 09:28:16 PM »
Hey brad if no good go to your local CBC Bearings and buy just plan round plastic bar they sell (in differing diameter), I use on my 84's as they have the same problem, just drill for bolt and use no bearing, get good life from them.
Cool looking RA mate how long have you had it for?? also good match for the 125 hey?
090
« Reply #4 on: December 31, 2008, 09:58:14 PM »
Thanks mate. Couple of months. Got it close to what you see, just put another set of wheels on it and the front end basically. The 125 RA is getting a make over and will look better than this girl as i am putting all the trick gear off the 125RZ on her, including the Simons. Cant wait to put them side by side!
STW996
« Reply #5 on: January 02, 2009, 01:44:30 PM »
The red in your blood is getting even thicker ;D ;D
Offline pancho
« Reply #6 on: January 02, 2009, 04:22:34 PM »
    ohhhhhhh   year so tis
