Author Topic: TL250 Honda  (Read 3048 times)
Offline matcho mick
    • Moto Tumbi
Re: TL250 Honda
« Reply #15 on: August 05, 2022, 11:24:48 AM »
what about a ball roller bearing behind the points,seen that done,slide fit on cam,just seal housing to be machined,would the XL 185/200 steel inset on the other end work as well as bushing there,btw TL head is physically smaller too than XL's circumference, :P
Offline sleepy
Re: TL250 Honda
« Reply #16 on: August 06, 2022, 11:03:36 AM »
There isn't much room behind the points and the cover from memory only has the seal area in it but the head has a small extra journal area. The 185 steel bush is the sort of thing that is needed but it is easier to make a new bush from bronze or alloy to fit the space after the cam and head have been re-machined back to round. Maching the head is a real prick as it is deep inside and almost impossible to see let alone measure while it is setup in the mill for line boring.
Offline Dungar Pilot
Re: TL250 Honda
« Reply #17 on: August 06, 2022, 01:20:47 PM »
Hi Everyone,
OK, so I could hear the gears grinding, does this help?
Let me know if you want more detailed photos? This is a centre port and came to exactly as is, I thought TL 250 so I grabbed it but stand to be corrected.....
