Marketplace
Wanted
WANTED. Forks to suit PE250B
Topic: WANTED. Forks to suit PE250B (Read 1948 times)
Canam370
May 28, 2022, 09:45:33 pm »
ISO forks to suit a PE250B. RM250a/b and RM370 will also suit. Good chrome preferred but not essential. Whatcha got?
LWC82PE
Superstar
Re: WANTED. Forks to suit PE250B
June 19, 2022, 06:37:42 pm »
Incase you don't know the PE forks are different to the RM. All the parts are different. Different length damping rods, sliders, inner tubes, springs, travel
Canam370
June 24, 2022, 07:15:13 pm »
All sorted. Used RM stanchions. All the PE bits fitted.
LWC82PE
Superstar
July 01, 2022, 08:16:03 pm »
PE250B
Slider – 345mm
Inner – 660mm
76/77 RM250 A/B
Slider – 355mm
Inner – 647mm
Fitting RM inner tubes will lower the front end. Probably not a good idea unless fitting shorter than standard shocks as well, as the PE is already low at the front and kinda hunched forward in stock form. Check clearance between triple clamp, wheel and top of sliders for clearance when forks bottomed out.
Last Edit: July 01, 2022, 08:18:21 pm by LWC82PE
Marketplace
Wanted
