Author Topic: Yamaha CDI with alloy case, two wire pulser with high and low charge coils wires  (Read 23258 times)
Offline YZB 500
Hi all,
Looking for a early model CDI unit to suit 1973-1976 Yamaha's with the white/red and white/green tracer wires, also has the brown and red charge coil wires.
I.D. number must start with TIA 01 ( single cylinder ) not TIA 02 is a twin cylinder CDI.
To suit MX250 1973- 75,  MX360 73-74, YZ250 & YZ360 A/B also YZ125C, all have black harness conduit ( Not blue )
Yamaha part number 364-85540-13.
My one does not advancing, its the CDI.
I have two bikes with same ignition system, one good CDi that advances on both bikes, one failing CDi that doesn't advance on either.
Regards Gibbsy
« Last Edit: June 20, 2020, 11:45:30 am by YZB 500 »
Old school is cool !
Offline Momus
I have one of those boxes. Condition unknown.  Message me if interested, Cheers Marcus.
If you love it, lube it.
Offline YZB 500
HI Marcus.
I can see the white/red and white/green pulsar wires and the brown low speed coil wire but the picture doesn't show the red high speed wire, doe's it have one?
the TIA01 cdi's come in several versions all have a two digit number followed by a three digit number, your one has a two digit number of 03, I am looking in that model code identifier.
I am looking for a TIA01-06 models such as YZ125 74/75 MX250 1973- 75,  MX360 73-74, YZ250 & YZ360 A/B also YZ125C, all have black harness conduit
TIA01-01 is a DT2MX 1972 cdi this model has black conduit.
TIA01-08 is a SC500 1973/74 cdi this model has blue conduit.
TIA01-10 is a MX175 1973/74 cdi this model has black conduit.
TIA01-16 is for YZ125X YZ125D YZ250C  YZ250D cdi this model has blue conduit and only one pulsar ire been white/red.
also Where in the world are you ?
Regards Gibbsy
Offline Momus
There is no red wire on that unit I showed Gibbsy.
 It came with some stuff included with an SC500 Kerry Marsh sold me and I'm unsure of it's provenance.
The parts manual shows a 7 wire CDI unit but no information on the code.
Good luck with sorting yours; at least you have a good ignition to diagnose from.
The SC was all unknown and after some mucking around with the parts supplied I gave up and acquired a stator from a YZ and a box from an IT.
Offline YZB 500
I had an issue with my 73 SC500 ignition and used a it250 one for a long time.
Just fitted a 74 SC500 ignition to my 73 SC500 motor.
Looking forward to testing and seeing with the additional weight over the IT250 flywheel has on the power delivery.
cheers, thank you for the response .
Regards Gibbsy
Offline YZB 500
FYI
So after looking though my Yamaha service data book and various web info.
the TIA 01 - 02 XXX cdi is the earliest production model I can find, this is a 1972 model.
the TIA 01- 06  XXX is a 1973 up for early mx and yz's to 76.
Putting the TIA 01 - 03 211 some where in the middle of that era.
so
TIA 01 is single cylinder
TIA 02 is for twin cylinders
TIA 04 is for the might inline fours
Also found same info suggesting its for a GPX292 snowmobile ( the X in the model code appears to be CDI models ? ), but I could only find a 1975 SR292 with a similar alloy case CDI with six wires in a parts diagram, also for a single cylinder.  all the single cylinder snow mobiles prior to 75 appear to be points ignition.
Black   = ground
Brown =  source coil
White/red & white/green = pulsar
Orange = HT coil pos  or cdi output to coil
and black/white = kill switch.
This TIA 01 - 03 211 is likely for a external flywheel been it only has one source coil input wire not an internal rotor style cdi which has two source coil inputs been brown and red ( low & high speed )
please add if more info comes to light.
Regards Gibbsy
Offline Momus
Gibbsy, good digging on the part#'s.
Not that this will be particularly helpful for you but you have spurred me to see if that  #3 box will substitute for the IT unit I have on the SC500and allow it to run.
I'm not sure that this is right but the early Yamaha CDI's seem to be more prone to issues than the Suzuki and Honda stuff from the same Pre75 era.
Offline YZB 500
Hearing on that, I have Elsinore's and YZs
My Elsinore's over 35 years and multiple bikes, I have had one source coil fail and that was must likely water damaged prior to me buying the bottom end and running with the stator
also had a issue with advance curve on one, tried all new electrical components which didn't fix it, plugged in a early 80's Suzuki RM cdi ( some stator manufacture )  and presto advance and retard curve for my big bore & stroker not a 125M. "sweet now"
YZ's on my thrid cdi failure, YZ B models with the CDI at the steering head are a issue for sure.
Pulsar coils on the DT360, MX400b to YZ400C so hard to find.
but with all that we keep doing it and coming back for more.
I have often thought, the 70s was a great era in regards to parts available today, dealers posted orders for parts and ordered parts that come in bags of ten.
The 80's saw a charge in logistics, fax machines and dealer stock levels.
The 90's saw a charge where you paid a deposit on the parts awaited for it to come from ex east.
how there's no dealer stock you pay in full, and in WA " Wait Awhile " is very true.
my Elsinore's still have a good supply of parts today 47 years on thank you to the internet, trying buying water pump parts and rear shockie and or fork parts, and power valves in 17 years time for early 90's bikes.
Buy up now and keep what you have but " Ride them don't hide them" and keep living the dream
Offline OverTheHill
Probably only confusing the issue, but i had a DT360A ride to work bike that stuffed the retard/starting side of the double pulser. Red/White & Green/White. Was a full flywheel [like an SC500] but same principle as the internal rotor YZ & double pulser same colours. Anyhoo--being to tight to go buy a pulser i found the advance side was ok. So wired it [not sure how 30 years later] so it was on advance from the get go. Just had to kick it right & not baby kick it or she'd bike like an older points mag 360. Decomp softened the blow though. 30 years ago but think i earthed the faulty side of the pulser [but if that sides faulty would earthing do anything] & earthed the un-used same wire out of the box--so say i used the Red/White & earthed the Green/White, but it worked & never looked back. Those advance in a one step not gradual like modern stuff & seemed to be purely a retard to help starting, then advance from just above kick speed & stay there.
But--now i realise your problem is the exact opposite with the box faulty so that stuffs my theory except can you cross wire something opposite to my stupid theory & make it work again--as in start & run on advance using the advance side of the box. Starting to wish i hadn't start typing lol. Sorry bout that.
But wait--there's more. If ya desperate i've got one bike [DT125LC] operating minus the pulser & using a Coil/Box combined from a little Suzy LT50/JR50/or RG50 road bike. Source coil had about 350 Ohms so just ran the single output wire straight to the Coil/Box [only one wire in or think was a kill wire connection too, but only one power wire in. I realise yours has a Red & a Brown so i dunno--earth one end & if that don't work then reverse the earthing end. Have a happy dayyy--.
Offline YZB 500
Cheers over the hill,
I have a loaner cdi for the weekend to run in a new bike to my YZ family, also find a better pulsar coil and installed that as well.
I have brought two cdi's new out of the UK, but both have failed to throw a spark as yet on two different capacity bikes with same stator and rotor combo.
Hoping the better pulsar coil is the answer to that issue, when testing.
But already thinking I might get a single wire pulsar cdi from a YZ250C and ground the white/green and see if that's a resolve are not.
Offline Momus
Gibbsy If you don't mind, are you using a digital car type timing light for your CDI
 tests?
Offline YZB 500
Momus :
 PM sent : re timing
Offline Momus
Thanks Gibbsy for the PM- pretty much same thinking/doing over here.
I'll post my latest CDI adventure here for the punters. I'm fitting an RM500 unit to my Pre65 JAWA.
The JAWA ignition is on the opposite side so the direction of rotation is reversed. Using my Xenon strobe and a motoring fixture mounted in the lathe I have determined the fire position and can time for the 2 mm or so BTDC that I will start with and tap the clamp screw holes to the base plate I made and fitted into the cases.
This whole thing may turn out to be a lot of trouble. As well as the CDI conversion I have fitted a TM250 piston which is 12 mm or so shorter than the original Czech 3 ring monster, so a lot of mucking around welding and machining cases and the cylinder ;D :( :D
« Last Edit: June 24, 2020, 03:02:56 pm by Momus »
Offline YZB 500
HI Gents
FYI
Had to research a cdi to ID it, turns out it not a TZ250/350 cdi bugger it.
so for the greater good Info !
Hitachi single cylinder CDI identification       Typically alloy or grey plastic housing
CDI model code               Type      Year      Model       Notes
TIA 01       01      2H      MC      1972      RT2MX
TIA 01       02            MC      1974      YZ250A
TIA 01       02      301      MC      1975      MX250B      unsure
TIA 01       03                 SLED      1974      GPX
TIA 01       04      209      SLED            SR292
TIA 01       05
TIA 01       06      304      MC      1974      MX250
TIA 01       06      305      MC      1974      MX360
TIA 01       06      305      MC      1975      YZ250B
TIA 01       06      305      MC      1975      YZ360B
TIA 01       06      312      MC      1976      MX
TIA 01       06            MC      1976      YZ125C
TIA 01       07
TIA 01       08      311      MC      1973/74   SC500
TIA 01       09
TIA 01       10      009      MC      1974       MX175
TIA 01       10      405      MC      1974       MX175
TIA 01       10      709      MC      1977      YZ100
TIA 01       10      812      MC      1977      TZ125 / YZ125
TIA 01       11            SLED      1977      SRX
TIA 01       12
TIA 01       13      211      SLED      78/79   SRX
TIA 01       14
TIA 01       15
TIA 01       16      511      MC      1977      YZ125
TIA 01       16      512      MC      1977      YZ125
TIA 01       16      701      MC      1977      YZ125
TIA 01       16            MC      1977      YZ125      1W2
TIA 01       16      710      MC      1978      YZ125      2K6
TIA 01       16      602      MC      1977      YZ250      1W3
TIA 01       17      707      SLED      1977      Exciter      Blue & white/black wire in cdi harness
TIA 01       17      710      SLED      1977      Exciter
TIA 01       18      605      SLED      77/79   Exciter
TIA 01       19
TIA 01       20            MC            CB400N      Honda
TIA 01       21      709      SLED            SSR
TIA 01       22      712      MC      1977      YZ250      2K7
TIA 01      23
TIA 01      24            MC      1981      YZ125H      4V2
TIA 01      25
TIA 01      26            MC      1979      YZ80F
TIA 01      26            MC      1980      YZ80G
TIA 01      26A            MC      1982      YZ80J      5X2
TIA 01      27      806      SLED      1979      Exciter      8H6
TIA 01      28      809      MC      1979      YZ250       2X4
TIA 01      28            MC      1981      YZ250       4V3
TIA 01      29
TIA 01      30      903      SLED      1980      Exciter
TIA 01      31            MC      1980      AG175      482
TIA 01      31      003      MC      1980      AG175      482
TIA 01      31            MC      1981      AG175      4M3
TIA 01      32      906      SLED      1980      SRX440      8K2
TIA 01      33      ?      SLED      1981      SRX440
TIA 01      34      912      MC      1980      YZ125G      3R3
TIA 01      34            MC      1980      YZ250G      3R4
TIA 01      35      007      MC      1980      YZ250G      3R4
TIA 01      36            Boat                  9.9hp 15hp 25hp
TIA 01      36A            Boat                  30hp 40hp
TIA 01      37            MC      1980      YZ125G      3R3
TIA 01      38      ?      SLED      1981      SRX
TIA 01      39            MC      82      YZ125J      5X4
TIA 01      40            MC      80/82   YZ465
TIA 01      40            MC      82      YZ250J      5X5
TIA 01      41      3302      MC            RD125      10W
TIA 01      42
TIA 01      43      2Y06      SLED      83/86   Vmax      8U9
TIA 01      44      230      MC      83/84   YZ125K/L      24X
TIA 01      45            MC      1981      YZ250H
TIA 01      45            MC      1983      YZ250K
TIA 01      46
TIA 01      47
TIA 01      48
TIA 01      49      309      MC            YZ125L      39W
TIA 01      50            MC      1984      YZ250L       39X
TIA 01      51      510      MC      1986      YZ125S      55Y
« Last Edit: August 04, 2020, 07:38:56 am by YZB 500 »
