Author Topic: help identifying forks  (Read 25871 times)
Offline brent j
« on: February 29, 2020, 07:35:50 pm »
Re: help identifying forks
« Reply #1 on: February 29, 2020, 08:25:25 pm »
Check out ER forks Brent. Look very similar
Offline mick25
  • Hunter valley NSW
« Reply #2 on: February 29, 2020, 08:26:39 pm »
Look a bit like XL500 forks I had some and they are 35mm
But could be XL250 to ?
Offline bazza
« Reply #3 on: February 29, 2020, 09:08:01 pm »
ER forks above have different shape up top with hole in (cable holder?) and look at brake hub holder it has different shape milled out of it
Embrace patina
« Reply #4 on: February 29, 2020, 10:42:11 pm »
True, the above are ER185
Perhaps DR as the legs have lower guard mounts as per trail bike. KL forks have usually two holes in the brake lug casting.
« Reply #5 on: March 01, 2020, 01:33:41 am »
no drain screws out the side on the ER,it will be interesting what there off of but someone on here will know,what about TY yams?
« Reply #6 on: March 01, 2020, 08:13:14 am »
TS250ER are 36mm so its not those.
They are either 79 TS250N or 82-85ish DR250S /SP250 USA
Suzuki still had the lower fender mount holes even if the bike had no low fender in Australia or USA for example. It was usually left in there because markets like UK and Germany required/wanted low mount fenders.
https://www.ebay.com/itm/Front-Suspension-Forks-35mm-for-Suzuki-DR250SF-DR-250-SF-1985ish/181527122130?hash=item2a43dc10d2%3Ag%3AIfwAAOSwY%7ElZ5vD%7E&LH_ItemCondition=4
cant find any 79 TS250 forks on ebay for comparison
« Last Edit: March 01, 2020, 09:38:20 am by LWC82PE »
Offline brent j
« Reply #7 on: March 01, 2020, 11:35:00 am »
Thanks Leith,
They look exactly like mine but the only exploded diagrams I can find are so indistinct they can't be read or they show no bushes.
I'm trying to find the part numbers for the bushes as they forks should be smoother than non bushed type
I'm also trying to find out the offset of RL fork lowers so I can compare them with the forks I have
« Reply #8 on: March 01, 2020, 04:43:34 pm »
Not TY, the twinshock 250s were 34mm. The monos are bigger but I can't remember the size, guard mounts are also horizontal at the top of the leg on the monos
« Reply #9 on: March 02, 2020, 05:06:18 pm »
Bushes you can get from Racetech and possibly https://www.teknikmotorsport.com or just go to https://www.ggbearings.com/en look throught their catalogues and find the correct size DU bush. Many bearing shops would be able to get them if you cant find them online unless 35mm is oddball special made just for motorbike forks and in that case you need to go to a place like RT or Teknik
Bushes in suzuki forks were not available as spare part pre 1981. Many pre 81 had bushes but they are not shown in parts books. They came in the sliders
