Author Topic: 1984 CR 500 Clutch Cover Wanted  (Read 4663 times)
Offline enzo906
« on: December 05, 2019, 09:18:39 am »
Hi
I am after a 1984 CR500 clutch Cover, prefer undamaged / repaired as I have one of those now looking for a good one.
Also if anyone knows which tank strap of the more modern bikes will suit an 84 cr 500 tank. The water cooled ones are too long and I was told a CRF150R would work  if anyone knows that would be helpful.
mrsupersport
Re: 1984 CR 500 Clutch Cover Wanted
« Reply #1 on: December 24, 2019, 05:18:33 am »
I have one that is pretty nice if you've not found. JOHN
Offline enzo906
« Reply #2 on: January 08, 2020, 09:47:31 am »
HI
I finally got your email today (you sent it last year???) Not sure what Yahoo.com.au is doing to me, I will respond there
Yes am interested also after a cylinder with no fin damage? and a tank rubber at rear that holds the tank to frame.
Original side covers and air scoops with no cracks or deep scratchs (deep as in when i remove them i take more than 1mm depth to do so)
most of the other parts I asked about I have now made from scratch, so only need the clutch cover and the aother bits above
Oh if you see a head, no fin damage with a decompressor in it I am after that too, needs to have the piece where air scoop bolts to it in tact also
mrsupersport
« Reply #3 on: January 13, 2020, 04:07:52 pm »
I got your email & sent you photos of the clutch cover. I also can get a cylinder w/ nice fins. Email me back. JOHN
