Author Topic: IT/YZ front brake plate  (Read 442 times)
Offline DJPresto
« on: July 15, 2019, 08:25:14 PM »
Wanted a IT/YZ front brake plate (possibly could use a DT one?). Cheers
Triumph Speed Triple 1050, Husky XC430 1982, Husky WR240 1985, GSX1100ez, Husky CR250 1975
Re: IT/YZ front brake plate
« Reply #1 on: July 16, 2019, 12:39:35 AM »
which model it/yz coz they aint all the same, c model had straight forks, d model leading axle forks and 6mm brake cable adjusting bolt, e model have 8mm brake cable adjusting bolt
Offline djr
« Reply #2 on: July 16, 2019, 01:32:00 AM »
Plus aren't there different diameters - most 130mm but a few bigger
{ 140, 150 160 or something ?  }
and the rare twin leading shoe type
YZ wont have speedo drive like DT & IT
Offline DJPresto
« Reply #3 on: July 16, 2019, 06:08:02 PM »
Ok I've measured the drum and it looks like it would take 130mm x 22mm shoes.
IT175, 250 1980/82
YZ125 76/83
YZ250 74/81
From what I can see.
I'm adapting the wheel to suit a Husky cr250 front end.
« Last Edit: July 16, 2019, 07:26:39 PM by DJPresto »
« Reply #4 on: July 16, 2019, 08:11:28 PM »
ok since its going on a husky set of forks theres a few options
dt175 monoshocks have a smaller axle compered to the it/yz's
g/h model it/yz have a much sort after twin leading shoe backing plate,like hens teeth to find and cost lots
tt600/yz/it's from k model on have twin leading shoe setup as well but mounting lug is at 3 oclock position instead of 1 oclock for the g/h models and easy to get
bigger front drum models are xt500 all models and dt250/400's and the xt's backing plate suits straight leg or leading axle forks
Offline mrsupersport
« Reply #5 on: July 17, 2019, 03:53:39 AM »
I have a TLS / DLS in USA if would work for you.
Offline DJPresto
« Reply #6 on: July 20, 2019, 08:08:10 PM »
that would be good if I could run it in pre1978 class but i doubt I can.
« Reply #7 on: August 25, 2019, 09:23:45 AM »
DT 175 , you can still buy NOS fits most Yamaha's , You can weld the lug to the Husky fork leg or make a arm that works , I have a mod that I do to the Husky Brake that makes nearly as good as the Yamaha.
