Author Topic: Anodizing  (Read 8783 times)
Offline Wasp
  • Your Suspension Solution since 1989
    • Suspensionshop
Anodizing
« on: June 11, 2019, 08:59:31 am »
Would anyone know or have educated guess when anodizing was first implemented by a manufacturer in  OEM part manufacturing ?
VMX shocks , We don't just sell them - I design and produce them individually for you since 1989.
Offline geoff
Re: Anodizing
« Reply #1 on: June 11, 2019, 11:31:13 am »
Hi Walter, Thinking back I had a 1973 Cheney B50 BSA with a blue anodized tank so it has probably been around for quite a while before Eric started to have his tanks done.
Offline Momus
Re: Anodizing
« Reply #2 on: June 11, 2019, 12:22:10 pm »
Manufacturers have been using it since the mid 1920's- so almost 100 years.
If you love it, lube it.
Offline Wasp
    • Suspensionshop
Re: Anodizing
« Reply #3 on: June 11, 2019, 12:44:29 pm »
Thanks for that info , the first time I have seen color anodizing , was on a Kramer-Maico around mid seventy . So Cheney was perhaps the first . I know  the process was invented 1923 for the aviation industry , but it must have taken years to find its way into European motorcycling and then much later to Japan . What year did the Japs fit the first anodized parts ?
Offline Momus
Re: Anodizing
« Reply #4 on: June 11, 2019, 02:54:53 pm »
Probably on wheel rims. Then as now the majors make hardly anything on bikes from wrought material suitable for anodising so most of it gets a paint type coating of some sort or is out of the weather well oiled. Edit. Color anodised throttle slides appeared on some Mikuni carbs mid 70s
« Last Edit: June 11, 2019, 08:39:43 pm by Momus »
Offline shoom
Re: Anodizing
« Reply #5 on: June 30, 2019, 08:34:30 pm »
Um, I saw astronauts with anodized air fittings on their suits in the mid 60s..
And weren't the original AN fittings back in WW2 time anodized too??
