Author Topic: Yam clutch spring specs- 90501-20122 & 90501-20124 ?  (Read 199 times)
  • ^^^ Jan 1984
« on: March 02, 2019, 12:59:18 PM »
Anyone with a range of Yamaha Clutch springs in stock be able to tell me the difference the following two clutch spring parts?
90501-20122
90501-20124
They both are listed for  a great many model Yams, both are listed for DT1 but one is listed for RT1; if one is a little stronger I'd like to get that one, TIA (Thanks In Advance).
Online sleepy
Re: Yam clutch spring specs- 90501-20122 & 90501-20124 ?
« Reply #1 on: March 03, 2019, 05:08:29 PM »
You may be better off trying some Barnett springs. Can't find a listing for DT1 up to RT3 but YZ360 for 1973 is listed as using MT-39-6 as is a lot of others after that.
Serco are the Barnett agents, give them a call and see if you can get a measurement to compare and if that fails get back to me and I'll see what I can find out.
« Reply #2 on: March 03, 2019, 10:53:36 PM »
the rt1 being 360cc would be the stronger springs you would think.on my bombed out tt500 which had a few different cams in it over the years I used stock springs and never had any slip despite the shite it got often
  • ^^^ Jan 1984
« Reply #3 on: March 04, 2019, 09:27:12 AM »
Thanks Guy's, l was interested in the two numbers that are quoted for the DT/RT's as l would have thought one set might be a little stronger, they share much the same other clutch components.  l am hesitant to go an aftermarket set of heavy-duty springs incase they make the lever pull too stiff, coil-bind or put undue stress on the worm-drive push mechanism.
