Author Topic: Pressing out swing arm axle  (Read 1468 times)
Offline FAT-TOY
« on: December 04, 2018, 08:33:53 PM »
   This is what can happen when you are pushing at over 50 tons using sockets.  You probably notice that they are not sidchrome. But they were reasonable quality.
   Zane
Re: Pressing out swing arm axle
« Reply #1 on: December 04, 2018, 09:54:36 PM »
be careful Zane, i would be wearing a face shield and safety glasses just in case that shattered. shrapnel  would make a mess.
Offline YSS
    • Suspensionshop
« Reply #2 on: December 04, 2018, 10:54:03 PM »
Looks pretty solid to me . Cheaper to buy another swingarm , I think.
362 shocks ,only  pay for performance and not for names
« Reply #3 on: December 05, 2018, 12:15:21 AM »
Holy crap , If it did that to a steel socket How deformed is the swingarm?
Offline bazza
« Reply #4 on: December 05, 2018, 06:59:07 AM »
Had you soaked for weeks first? squirt coke, atf, roost off? then wack/ re squirt etc. Frustrating little feckers
Offline fred99999au
« Reply #5 on: December 05, 2018, 07:52:17 AM »
Did that with a mate who was new to bikes. Used his new socket set from bunnings in my 20 ten press and made it into a washer.
« Reply #6 on: December 05, 2018, 09:34:25 AM »
aint stuck swingarms a bastard >:(
Offline topari
« Reply #7 on: December 05, 2018, 10:02:07 AM »
Alternatively one could deploy air tools or use a rotary hammer. The constant banging usually breaks the bonds which bind the axles. We removed a stubborn axle with a rotary hammer and it took about 10minutes before the bonds let go and axle started to move. No collateral damage.
topari
1979 IT400F, 1984 kdx200
Offline FAT-TOY
« Reply #8 on: December 05, 2018, 08:02:38 PM »
  The axle had been cut, and all I was given was the centre section that was stuck in the rear engine mount section.  I ended up machining a pin to push with and a tube to push the axle section into, which is what I would normally do, but I didn't expect this 60mm long bit to be quite this tight.  Once it started to move I kept it going.  It did a fair bit of banging and complaining, but with 50 ton up it's arse it was never going to win.  The mount section had a few rough bits inside the tube but a quick ream had it looking like new.
  Zane
« Reply #9 on: December 07, 2018, 06:34:04 PM »
What was the swingarm out of? I'm figuring my sidepipe is going to end up like that although the engine mount won't be the only place it's seized
Offline FAT-TOY
« Reply #10 on: December 07, 2018, 06:44:35 PM »
  Tony I think it's out of a Bultaco but don't know what model.  The owner had spread the frame a little then cut the axle either side of the engine mount section and then managed to free the 2 remaining axle sections from the frame and swing arm.
   Zane
« Reply #11 on: December 08, 2018, 03:13:59 PM »
Wish that would work, my pivot is the proper sidepipe type with a head rather than a bolt in from both ends. Have been considering ordering a new engine mount from etovar.cz & cutting the original mount up
« Reply #12 on: December 08, 2018, 04:11:28 PM »
I did a tough one a few years back, sat the frame with motor sideways in the press and hit the engine mount with a mixture of oxy heat and cold and lube sprays.
It took 3 days for it to break free, giving the press another pump every hour when I was in the workshop to keep the pressure up along with another spray. (don't try to force it out in one go)
If you have time (and a press) on your side you have nothing to lose
It's usually the bolt and steel sleeve of the engine mount that rust themselves together
« Reply #13 on: December 09, 2018, 12:52:47 AM »
I had a rusted swingarm bolt on a xt500 and I got it out after a month of spaying with wd40 every time I went near it,i still had to support the frame with a spocket for the bolt to go into and I used an stepped shaft the kids make at machining course at tafe along with an 7 pound hammer.i got after the 3rd blow and when out I could see the fish oil in the wd40 had softened the rust on the axle and bearing sleves.see a lot using high pressure sprays at the car wash cleaning dust off their bikes (I live near a desert) and I think poor dude who got to remove the s/arm bolt next!
Offline Colin Jay
« Reply #14 on: December 09, 2018, 09:32:41 AM »
A few months ago I resorted to the hacksaw method to get the seized swingarm pivot out of my brothers 1978 KTM 400.
The brother had tried to remove the swingarm about 10 years ago to start restoration of the bike, but when he could't get the swingarm pivot bolt out (seized in the bearing tube) he gave up and the bike went back to it normal position in the back of his shed.
The brother had been able to get the pivot bole to move a few mm by use of brute force / extreme violence before he gave up. This made enough room for me to get a hacksaw blade between the frame and the end of the swingarm pivot. Because KTM pivot bolts are made of some really good steel, it took 2 hacksaw blades to cut through each end of the pivot bolt. Once the swingarm was free from the frame, the tube nuts on the end of the swingarm pivot tube (they are a KTM thing) were easily undone and the pivot tube just slide out of the bearings. Luckily, all the required part are still available, so I didn't even try to get the pivot bolt out of the bearing tube..
Offline alexbrown64
« Reply #15 on: December 11, 2018, 01:14:07 PM »
A while back, my YZ125G swingarm bolt was fully seized in.
I soaked it in all sorts of stuff for days.
I used a propane torch to continually heat the area.
I was lucky that one end of the swingarm bolt had a hex head where i could get an impact air driver on and continually work on it forward and reverse.
I used a Hilti to continually hammer on it.
The combination of heat, lube, hammering, torquing and time eventually started to gradually turn and move it mm by mm.
After a few days of continual work, it came out.  The bolt was ruined of course, but everything else was fine.
« Reply #16 on: December 22, 2018, 04:20:59 PM »
Just got a grinder onto one a few days ago.
This looks like another option https://www.youtube.com/watch?v=OcESnOmU5Y0
« Reply #17 on: December 22, 2018, 09:43:14 PM »
that big home made slide hammer looks the go but ive found for really rusted in s/arm bolts a month soaking with wd40 is the way.
« Reply #18 on: December 31, 2018, 07:34:33 PM »
Pulling it out also prevents spreading/bending the end when you try and push through from the nut side...
« Reply #19 on: January 01, 2019, 01:21:02 AM »
true it would prevent frame speading compared to just bashing the bolt out with the biggest hammer you can find but best way to prevent the bolt seizing in the 1st place is remove often and put plenty of grease on it before reassembly then no problem done the track,something that could be done at a factory level as they assemble dry when it comes to axle/swingarm and engine mounting bolts.im not a fan of high pressure washers/cleaners as at 2000psi the water goes into places you don't want it to go,i prefer the old bucket of soap suds/a sponge and good old low pressure hose/elbow grease,takes longer but you get in where the blaster wont and the bike looks a lot cleaner
Offline topari
« Reply #20 on: January 01, 2019, 01:30:08 AM »
Prevention is good. But in my case the bike had been parked for 18years. An electrical problem got the better of the owner. So these  problems become the challenges for new owners.
topari
« Reply #21 on: January 01, 2019, 01:46:33 AM »
yeah some owners never remove the swingarm bolt to lube it and unknowingly pass the problem on to the next buyer,been there done that times 3 so far
