Author Topic: Pro-Form exhaust fit  (Read 785 times)
Offline maxi81
« on: September 08, 2018, 10:44:18 AM »
Hi all. I have a Pro-Form exhaust on my RM 400T at the cylinder head I can't seem to get a good seal, a little bit of smoke seems to leak out and oil gets on the front mudguard. Is there some sort of sealant I can use to stop it leaking?
  • ^^^ Jan 1984
Re: Pro-Form exhaust fit
« Reply #1 on: September 08, 2018, 11:17:13 AM »
I've had to cut & weld both PFR pipes l have bought for KX250A5's, one at the header for the problem you have.
« Reply #2 on: September 08, 2018, 03:01:30 PM »
i use Red RTV high temp silicon on my bike, it lasts for a few meetings.
https://www.supercheapauto.com.au/p/permatex-high-temp-rtv-silicone-gasket-maker---red-85g/114981.html
« Reply #3 on: September 08, 2018, 08:01:55 PM »
just use common or garden silicon...1. clean all oil residue so its spotless. 2. fit it up and leave it set for 24 hrs or more before using. will last a few rides.
Offline bazza
« Reply #4 on: September 09, 2018, 12:13:49 PM »
Red RTV heat proof silicone
Embrace patina
Offline maxi81
« Reply #5 on: September 10, 2018, 11:25:36 AM »
Thanks for the replies. I will give the red silicone a go.
« Reply #6 on: September 10, 2018, 08:51:27 PM »
The tip I was given when using the red silicon was to let it sit long enough to form a skin before fitting & then don't fully secure it until the next day
Offline ralph311
« Reply #8 on: September 11, 2018, 02:10:22 PM »
whatever you use, leave it sit! my old kdx took a punt to the pipe and leaked pooh everywhere so after every enduro i would strip it, wire brush it, load it up with roof and gutter, reassemble it and leave it for at least over nite. Always lasted for a few rides and a big event before it started splooging out.
