Author Topic: YZ465H / YZ490 82 Piston Clearance  (Read 502 times)
Offline smalls717
« on: June 20, 2018, 12:45:28 PM »
Managed to get a 81 YZ465H with matching numbers engine / frame.... except for the barrel.. the stampings show its a 82 YZ490 Barrel.
I've searched the web but haven't managed to find a definitive answer to the piston clearance... would 6 thou be the answer ? A quick measure with a feeler gauge whilst the barrel is on shows 15 thou + way too much...only did this as I could physically see the gap between the piston and bore is way too big... walked away feeling depressed. I'll take the barrel off and get a correct measurement...
would it be worth getting a new piston / rebore or try and source a 465 barrel ? from what I've read the 490 wasn't as good / vibrates / etc. :'( ?
« Last Edit: June 21, 2018, 07:20:00 AM by smalls717 »
Offline sleepy
Re: YZ465H / YZ490 82 Piston Clearance
« Reply #1 on: June 20, 2018, 02:35:09 PM »
Service specs here.
http://vintage38.tripod.com/IT425_490.pdf
82 YZ 490 clearance listed as .08-.085mm or about .0035"
