Author Topic: 4681 Springs  (Read 3255 times)
Offline Wasp
  • Your Suspension Solution since 1989
    • Suspensionshop
4681 Springs
« on: May 22, 2018, 03:36:36 PM »
Its time to clear a few shelves . I have alot of White Power  mono springs to clear out .  Some are OEM replacement springs ( 82-90)  and most are to suit the WP 4681. ( Both ends 59 mm ID .  They are in lengths of 260, 270, 290 , 300 and 320 . If its a specific  spring rate you are after , just ask . They are new , but due to age and moving them around over the years , some may have slight marks . Cost $95 per spring or less for bulk buyers . 08 82848033 BH
« Last Edit: June 01, 2018, 10:56:47 AM by YSS »
VMX shocks , We don't just sell them - I design and produce them individually for you since 1989.
Re: 4681 Springs
« Reply #1 on: May 22, 2018, 05:00:41 PM »
did i read that right Walter, you have 2500 WP springs to to clear ?
whats a 4681 ? is that the model number of the shock ( don't know what model shock i have its on a 86' CR250 and 85' CR500 )
« Last Edit: May 22, 2018, 05:02:34 PM by Hoony »
Offline Wasp
    • Suspensionshop
Re: 4681 Springs
« Reply #2 on: May 22, 2018, 05:28:51 PM »
Yes Hoony ,way too many . Imagine the kids getting 600 springs each as a inheritance . LOL . I think they will prefer the folding stuff moor . Better to reduce them in price  and move a few to make room for current stuff . 4681 is the normal WP shock like you have  . (Non PDS )
« Last Edit: May 22, 2018, 06:07:58 PM by YSS »
Re: 4681 Springs
« Reply #3 on: May 22, 2018, 05:47:55 PM »
Whats the best way to determine your current spring rate? Somewhere between 7.8 to 9.7 kg/mm.
Offline Wasp
    • Suspensionshop
Re: 4681 Springs
« Reply #4 on: May 22, 2018, 07:10:08 PM »
Get it tested  or find out from the manufacturer. Every good bike shop should have spring tester. Alternatively you can compress the spring 10 mm on the scales . That will give you the rate in kg / cm , or compress it one mm that will give you the approx . N/mm
Re: 4681 Springs
« Reply #5 on: May 22, 2018, 07:15:31 PM »
Thanks Walter, Do you have them in 220mm in that range?
Offline Wasp
    • Suspensionshop
Re: 4681 Springs
« Reply #6 on: May 23, 2018, 09:24:40 AM »
Please just PM or call with the following dimensions : ID top , ID bottom , Free length  and spring rate required . They are going cheap and we need easy  and quick transactions . ;)
