Author Topic: Sloppy 34mm forks  (Read 326 times)
Online tony27
Sloppy 34mm forks
« on: October 29, 2017, 07:32:06 PM »
I need to fit bushes to the top of my TY250 forks as both legs blow seals & if I grip each leg with the wheel out there is definite play in them
Does anyone know of a 34mm fork that has bushes in the top of the sliders or am I going to need to custom make a pair with a fairly thin wall thickness?
« Last Edit: October 30, 2017, 07:35:10 PM by tony27 »
Re: Sloppy 34mm forks
« Reply #1 on: October 29, 2017, 07:58:32 PM »
Possibly need to make them
Race Tech does not have 34mm
http://www.racetech.com/HTML_FILES/FMB-ForkBushings.html
Or try a bearing shop who has these
https://www.ggbearings.com/en/products/metal-polymer
Wanted - 1978 TS185 frame
Orange Don Vesco/MS/Windsor tank
ADB Mags (vol 2 no.2) nov/dec 77& jan/feb 78 (vol2 no.3)
Offline crossedup2
  • Never enough shed time.....
« Reply #2 on: October 30, 2017, 12:44:10 PM »
I will have the fork legs machined and these inserted in my RT1 racer over Christmas.
Any good machine shop should be able to do it!
http://www.ebay.com.au/itm/38-1006-ALL-BALLS-INNER-FORK-BUSHES-34-7-X-36-6-X-19-8-2-PCS/161348133783?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
If I had a half decent lathe I'd have a go myself. Can't be that hard!
Peter B
Anything Yamaha. AT1, CT1 (X3), RT1, DT3 (x3), YZ125X,  YZ250E, YZ400D, IT175E, IT250H, IT490K . Always looking for Pre 78 Yamaha stuff....
Online tony27
« Reply #3 on: November 04, 2017, 10:29:16 AM »
So far the bushes listed over the counter are either 32mm or 35mm bore so it looks like it may end up being bronze bushes made to fit
