Author Topic: suzuki PE 250B FRONT BRAKE CABLE  (Read 619 times)
Offline PERM250
« on: September 30, 2017, 12:58:26 PM »
HI JUST WONDER IF ANY ONE MAY HAVE A PE 250B FRONT BRAKE CABLE FOR SALE OR KNOW OF SOMEONE THAT MAKES AFTER MARKET CABLES OR CAN MAKE A NEW ONE UP.CHEERS THANKS
Offline pecrazy
Re: suzuki PE 250B FRONT BRAKE CABLE
« Reply #1 on: September 30, 2017, 01:02:14 PM »
What ends does it have? may have one. Nope just found it, genuine Suzuki part no.58200-41301, looks like early RM.
« Last Edit: September 30, 2017, 01:26:38 PM by pecrazy »
« Reply #2 on: October 01, 2017, 01:42:02 PM »
DR500S cable should work. DR forks are only about 12mm longer so length will be much the same. Most other RM/PE forks are longer so you could have issues with extra cable length not needed so thats why i sugest the DR500S cable. You will need to check the front brake plate. Does the adjuster thread in or just slip in? You may need to use a 78 or 79 PE250 front brake plate or maybe even a 79-82 TS250 brake plate. they are all much the same, still have under slung speedo drive, its just there is a difference with the way the cable is retained to the brake plate. I got a box full of plates and i could check for you. Another option SP370 78/79 cable.
« Reply #3 on: October 01, 2017, 04:26:33 PM »
Look for an current AG bike cable , they are often long enough as they need to clear racks. Yamaha still have IT / XT cables in stock. Or take your old one to the bike shop and find the best match.
Offline fred99999au
« Reply #4 on: October 01, 2017, 07:13:18 PM »
Or Remar Cables in Trafalgar in Vic. He can make many things.
Offline PERM250
« Reply #5 on: October 02, 2017, 10:29:05 AM »
Thanks very much for all your help thanks these tips will help.
Offline Oldfart
« Reply #6 on: October 16, 2017, 04:04:30 PM »
Mr perm ...  if you call in I will loan you a Dr 500 cable to check against.
