Author Topic: 83 Honda XR500 Conrod Kit Unavailable  (Read 5252 times)
Offline HL500
« on: August 31, 2017, 01:51:47 PM »
Hi.I am hoping the combined knowledge and experience of forum members may have struck this issue before.
I am reconditioning a Honda 83 XR500 engine and would like to fit a new conrod kit which I have sadly discovered is not available.
I have found a few interesting sites that discuss fitting XL600 conrods and the like but there seems to be a lot of machining and work in order to do that, which I will if I have to.
Has anyone got advice on this subject at all or by a miracle, actually have a new kit they have left idle and unused in the drak regions of a shelf?
Any help or leads would be greatly appreciated.
Regards John
Offline alexbrown64
Re: 83 Honda XR500 Conrod Kit Unavailable
« Reply #1 on: August 31, 2017, 05:22:15 PM »
Not trying to get your hopes up, but this dutch site reckons they have the ProX rod kit for the XR500RD/RE in stock.  https://www.braking.nl/default/03-1554
They are saying the kit is Product op voorraad  which means product in stock.  Worth giving them a go.
I did have a look through all my old emails to see if and when i did my crank on my 83.. but i never did it. New piston and rings, timing chain etc.. but it sits in the mancave now.. she did her work a long time ago..
Offline sleepy
« Reply #2 on: August 31, 2017, 05:32:29 PM »
Are you sure it's the 83 model? The rods for the 82 are available but have a 2 mm smaller pin and are 8 mm longer.
XR600 looks like 2 mm bigger pin and 2 mm bigger small end, wouldn't be to hard to fit up
There is a 650 rod that has the same size pin but it is 1 mm shorter and has the 24 mm small end, still machining required which ever way if you can't get the correct one.
Offline alexbrown64
« Reply #3 on: August 31, 2017, 05:34:19 PM »
Offline alexbrown64
« Reply #4 on: August 31, 2017, 05:41:16 PM »
Pro X rod kit for 83-84 XR500 is 03.1554 Seems to be the same part number as the Mitaka kit for the 83-84 XR500R. If you look up the Mitaka 03.1554, it gives you all the dimensions..
http://www.mitaka.co.uk/ROD%20DATABASE/PAGE.html
Offline sleepy
« Reply #5 on: August 31, 2017, 06:40:55 PM »
The dimensions on the Mitaka site are wrong. They have the length as 134 mm when it is 133 mm long.
Offline HL500
« Reply #6 on: August 31, 2017, 08:54:15 PM »
Thanks a lot for replies. I am going to follow up then suggestions.
If anyone is interested I have a C&J frame kit I brought from Austria.  I am fitting the 83/84 engine instead of the usual 82 motor. Obviously a lot of differences including the original dual carbies.  I am casting a new manifold for a single larger pumper carbie and doing a few modifications to the motor.
« Last Edit: August 31, 2017, 11:36:01 PM by HL500 »
Offline HL500
« Reply #7 on: August 31, 2017, 08:58:00 PM »
Great looking bike. I tried to reach the site you gave but its not connecting. Can you give me the company name?
Offline alexbrown64
« Reply #8 on: August 31, 2017, 10:47:55 PM »
I dont know about the sizes Sleepy. The kit is supposed to fit the  83 XR.
You can email them on info@hgasport.nl  ask them a few questions.  Most dutch speak pretty good English.
Company is Braking, website is braking.nl
Offline HL500
« Reply #9 on: August 31, 2017, 11:36:49 PM »
I've sent off a few emails.
Thanks for the help
Regards
John
Offline djr
« Reply #10 on: September 01, 2017, 04:31:14 AM »
this is probably no help to you but - cmsnl.com are showing a complete crank with rod at 1099 euros !   for 83-84 XR500
I cant really see it selling at that price, maybe worth a call/email to see if they could do a sensible price
I am sure you have tried - davidsilverspares.co.uk {big Honda specialist in uk}
good luck with your search
Offline crossedup2
  • Never enough shed time.....
« Reply #11 on: September 01, 2017, 09:18:48 AM »
XR's Only in US have the big end bearing kit if you can find the rod. Plus other kits. I used them a few times and their mail service has been very quick.
http://www.xrsonly.com/catalogsearch/result/?q=rod+kit
If you contact them they may have a supplier for the rods.
Peter B
Anything Yamaha. AT1, CT1 (X3), RT1, DT3 (x3), YZ125X,  YZ250E, YZ400D, IT175E, IT250H, IT490K . Always looking for Pre 78 Yamaha stuff....
Offline sleepy
« Reply #12 on: September 01, 2017, 09:25:53 AM »
That is the correct Pro-X part number for the 83 XR500 but Pro-X haven't made them for several years and are listed as no longer available. There were some Long brand kit around but are also no longer available.
Not a big fan of Mitaka as I've seen a few problems with their product. One that spring to mind is their YZ465/490 rods being .5mm shorter than original.
Offline HL500
« Reply #13 on: September 02, 2017, 08:59:45 AM »
Yea, saw the new crank for sale. Bit out of my price range. The other suggested suppliers have all come up blank.
Offline HL500
« Reply #14 on: September 02, 2017, 09:01:40 AM »
Peter B
Hi. Tried them from the start. Getting some other stuff from them.
