Author Topic: 6 Volt 2-Pin flasher relay for LED's  (Read 430 times)
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« on: August 24, 2017, 05:20:22 PM »
Can anyone direct me where to get a 6 Volt 2-Pin flasher relay which works with LED replacement bulbs. Have tried these 2 but both are no go for flashing
http://www.ebay.com.au/itm/Electronical-LED-flasher-relay-for-universal-use-on-6-Volt-bikes-motorcycles-6V-/360558335764?hash=item53f2f39714:m:mfHMYa-oI9ijJnbQu-ebBCA
http://www.ebay.com.au/itm/BIKINGEAR-MOTORCYCLE-UNIVERSAL-6-12v-VOLT-LED-INDICATOR-FLASHER-RELAY-NEW-HOT-/192287262411?hash=item2cc536c6cb:g:CrkAAOSwQTVV8i9Z
The last one only works on 12v bikes, the first one lights up but won't flash.
Ban BLACK rims NOW
Re: 6 Volt 2-Pin flasher relay for LED's
« Reply #1 on: August 24, 2017, 05:54:27 PM »
6v for LED might be a hard one. Have you looked in the MCS catalogue? Or maybe try
http://www.norbsa02.freeuk.com/ because he specializes in 6v & LED stuff
Offline DR500
« Reply #2 on: August 24, 2017, 06:36:06 PM »
put a resistor in to increase load, then should turn on/off
« Reply #3 on: August 25, 2017, 08:25:42 PM »
Those electronic relays should work without resistors as there just a on/off switch on a timer
