Author Topic: twin piston brake caliper mount  (Read 358 times)
Offline gmc65
« on: July 24, 2017, 04:25:01 PM »
Gents after the alloy brake caliper axle mount that the upsd forks screw into its is twin piston of 87/88 series ktm mine has cracks both sides am getting it welded but cracks are long.Also if welding them do i need to remove it from the forks or can it be done as is.Will look at buying complete forks if need be Cheers Greg
Offline YSS
  • Your Suspension Solution since 1989
    • Suspensionshop
Re: twin piston brake caliper mount
« Reply #1 on: July 24, 2017, 07:06:00 PM »
I guess you are after the 4054 mounts . I have the new Grimeca and the Brembo ones used 86-90 still in stock . 08 82848033 BH .
362 shocks ,where you only  pay for performance and not for names
Offline gmc65
« Reply #2 on: July 24, 2017, 09:27:34 PM »
Cool will call you tomorrow cheers
