Author Topic: M2 1976 CR250 timing URGENT!!  (Read 1111 times)
Offline bazza
« on: July 09, 2017, 11:34:07 AM »
Thanks mike
Also is M2 1976 timing 1.5mm BTDC ?
« Last Edit: July 18, 2017, 03:14:18 PM by bazza »
Embrace patina
Offline sleepy
Re: M1 CR250 Points gap and timing
« Reply #1 on: July 11, 2017, 06:36:56 PM »
Only got a manual for the "M" model but it has the timing at 1.5mm and the points 12 to 20. Points gap is not critical on something like that, just set the points then do timing.
Offline bazza
Re: M2 1976 CR250 timing URGENT!!
« Reply #2 on: July 18, 2017, 03:15:19 PM »
urgent please
Embrace patina
« Reply #3 on: July 18, 2017, 09:36:34 PM »
see if you can get hold of macka McKenzie, he knows the elsinores inside out. i think he is gold coast motorcycles???
Offline ajcmbrown
« Reply #4 on: July 20, 2017, 03:37:13 PM »
Well I'll be buggered, I had no idea that was Wayne!
« Reply #5 on: July 20, 2017, 09:03:38 PM »
if its the same as the 73/74 all you need is a set of feeler gauges and a cigerette paper
the timing mark should be on the plate aline the two pointers as the paper is pulled out of the points ie just opening
thats how i used to do it
jim
