Author Topic: Suzuki RM80 B or C  (Read 606 times)
Offline Richo52
Suzuki RM80 B or C
« on: June 23, 2017, 10:43:52 PM »
Any parts out there for an RM80 B 0r C 1977 /1978 models PM me or phone 0437801714 cheers Richo.
SOME BIKES AND CARS
Re: Suzuki RM80 B or C
« Reply #1 on: June 25, 2017, 09:44:00 AM »
Good luck they are pretty scarce on the ground What bits in particular are you after?
Offline Richo52
« Reply #2 on: June 26, 2017, 12:48:36 PM »
a tank and a motor specifically thanks.
SOME BIKES AND CARS
Offline alexbrown64
« Reply #3 on: June 27, 2017, 11:03:51 AM »
Did you know that the jr80 uses the same engine as the original rm80b. Yep, same 5 speed box, crank, cases, etc.. It's just detuned. So, if your after an engine, consider building one up using Jr. Parts. Cylinder heads are identical (I have a b, n and Jr head), and can be found for ten bucks.
Offline alexbrown64
« Reply #4 on: June 27, 2017, 11:42:52 AM »
The ds80 engine is also the old b engine. There is a old one on eBay for sale that could be rebuilt... http://www.ebay.com.au/itm/Suzuki-Ds80-engine-motor-/122529540384?hash=item1c87546920:g:xCUAAOSwsXFZMWFq
Offline alexbrown64
« Reply #5 on: June 27, 2017, 11:52:50 AM »
Offline Richo52
« Reply #6 on: June 28, 2017, 01:12:16 PM »
Good on you Alex,thanks will check it all out.Richo
SOME BIKES AND CARS
